Старый 24.05.2011, 16:48 #2
Сказал спасибо: 1,550
Поблагодарили 10,550 раз(а) в 1,957 сообщениях
  • На эту же тему брошюра Системы подвесок BMW (Suspension Systems). 40 страниц. Язык - английский.
Содержание:
Purpose of the System .................................................. ...................... 3
Basic Suspension Geometry .................................................. ............. 4
Caster .................................................. .................................................4
Camber .................................................. ...............................................5
Toe .................................................. .................................................. ....6
Steering Roll Radius .................................................. ............................7
Steering Axis Inclination .................................................. ..................... .8
Toe-out on Turns .................................................. .................................9
Geometric Axis .................................................. ...................................10
Suspension Systems .................................................. ..........................11
Single Joint Front Suspension .................................................. .......... ..11
Double Pivot Front Suspension .................................................. .......... 14
Rear Suspension Systems .................................................. ................ 16
Semi-Trailing Arm .................................................. ................................17
Semi-Trailing Arm with “Track Link” .................................................. .....18
Central “C” Link .................................................. ..................................19
Multi-Link Suspensions .................................................. .......................22
Alignment Procedures .................................................. ...................... 28
Vehicle Inspection .................................................. ...............................29
Ride Height Measurement .................................................. ... ...............30
Identification of Suspension .................................................. ....... .........32
Vehicle Loading .................................................. .......................... ........34
Alignment Specifications .................................................. .....................36
Alignment Checklist .................................................. ................... .........38
Alignment Worksheets .................................................. ........................39
Review Questions .................................................. ...............................40
Скачать бесплатно - в приложенном файле.
Тип файла: pdf www.bmwpost.ru_ST056 - Chassis Dynamics (Archive 1).pdf (1.28 Мб, 132 просмотров)
Эти 3 пользователя(ей) сказали Спасибо Tyler за сообщение:
autoface1 (09.01.2024), Mad-Mike (06.12.2015), Лёха 07 (09.01.2013)
