Старый 09.10.2011, 23:24 #2
Сказал спасибо: 1,550
Поблагодарили 10,550 раз(а) в 1,957 сообщениях
IFH-0003: Data transmission HOST/Interface failed
Reason 1: In the Ediabas.ini file, the interface is set to STD:OBD. However, you have connected an ADS connector.
Solution 1: Modify the interface setting.
Reason 2: The data transmission failed when sending (e.g. short circuit in the line).
Solution 2: Get rid of the short circuit, for example.
Reason 3: Connector not connected or no power supplied.
Solution 3: Check whether the connector is connected and is supplied with power.
Reason 4: The device manager has been used to disable the FIFO buffer for COM1.
Solution 4: In the device manager (Windows XP: Enter “Start” à “Control Panel” à “System” à “Hardware” à “Device Manager” à Ports (COM & LPT)), and then select COM1 from the ports. Then under the “Port Settings” tab, select “Advanced”. There must be a check-mark by “Use FIFO buffers” and “8” must be selected for the receive buffer and transmit puffer.
Reason 5: Умер адаптер.
Solution 5: Купить новый или поменять старый по гарантии.
