Старый 12.10.2009, 16:47 #30
Поблагодарили 20 раз(а) в 5 сообщениях
Сообщение от LifefaN Посмотреть сообщение
Вот кое чего есть:
E39 Car and Key memory programming using NCS Expert in the Edibas package.
AUSSENTEMP_WARNUNG_GONG : External Low Temp Warning Gong
AUT_SITZVERSTELLUNG : Automatic Seat Adjustment (select when unlocked or when driver door opened) linked to key number
AUTO_ZV_DISABLE : (automatic central locking ?)
BC_KL_R : Interior lighting ON when ignition is switched off after driving with headlights on
DWA-QUITTIERUNG : DWA Acknowledgement
EINSCHALTMELDUNG_IMMER : Power-up messgage always
ERKENNUNG_SITZBELEGUNG_1 : Recognition seat allocation (don't switch this off otherwise the airbag system gets up-set)
FH_BEIFAHRERTUER_TIPP_AUF : FH Passenger Door Window Up (one touch window passenger door)
FH_BEIFAHRERTUER_TIPP_ZU : FH Passenger Door Window Down one touch
FH_FAHRERTUER_TIPP_AUF : FH Passenger Door Window Up one touch
FH_FAHRERTUER_TIPP_ZU : FH Passenger Door Window Down one touch
FH_TUEREN_HINTEN_TIPP_AUF : doors in rear Window Up one touch
FH_TUEREN_HINTEN_TIPP_ZU : doors in rear Window Down one touch
fussraumkurven : Floor Space-Circle ?? Could it be: FuЯraumklappen: Floor flaps (IHKA)
HBA_DSC_5_7 :
HECKKLAPPE_ENTSICHERN : Rear BootRelease from remote key
HEIMLEUCHTEN : Home Shine (Follow me home lights)
INNENLICHT_AN_MEHRFACH_ZV : Interior Light On Several Times
KEY_MEMORY_IHK : Key Memory IHK Module (A/C temperature memory from key number)
KEY_MEMORY_RADIO : Key Memory Radio (Radio channel / volume from key number)
KOMFORTOEFFNUNG : Comfort Opening
KOMFORTOEFFNUNG_FB : Comfort Opening
KOMFORTSCHLIESSUNG : Comfort Closing
KOMFORTSCHLIESSUNG_FB : Comfort Closing
LAUTSTAERKE_HINTEN : Volume in the Back
NOTSTROMSIRENE : Emergency Power Siren
QUIT_OPT_ENTSCH : Acknowledge remote un-locking (two flashes)
QUIT_OPT_SCHAERF : Acknowledge remote locking (one flash)
SCHIEBEHEBEDACH_TIPP_AUF : One touch sun-roof open
SCHIEBEHEBEDACH_TIPP_ZU : One touch sun-roof close
SOFT ON/OFF : Soft dim/undim of the interior lights
SPRACHE : Language selection
TAGFAHRLICHT_ECE : Dayligh Headlights
TEMPERATUR_EINHEIT : Temperature Unit (C/F)
UMLUFT MEMORY : Circulating Air Flap Memory (remembers if re-circ is on after shutdown)
VERBRAUCH D1 : Consumption units
VERRIEGELN_AUT_AB_X_KMH : Automatic locking after X KMH
VERRIEGELN_AUT_MACH_2_MIN : Automatic locking after 2 MIN
VERRIEGELUNGSSCHWELLE : Bolting Device-swells (speed of X above)
WEG_EINHEIT : Distance unit (distance, miles or km)
ZEIT_EINHEIT : Time unit (12H or 24H)
ZUENDSCHLUESSEL_WARNUNG : Ignition key Warning, a really anoying option which beeps if you leave the key in the ignition
ZV_SELEKTIV : ZV selectively (selective unlocking)
Each individual key can also be set to allow selective un-locking and automatic locking after X MPH.
E46
ENTSICHERN_CENTERLOCK : Release central locking
FUNK_INNENRAUMSCHUTZ : Radio interior space monitoring
FUNKTIONTUERSCHLOSS : Function Door Lock
FUSSRAUMKLAPPE_SCHLIES_1 : Floor space flap
HHS_AUTOMATIK : HHS Mechanism
HKL_SPERREN_BEI_ZS : HKL Barriers with ZS
IB_BEI_KL.R_AUS IB at KL.R off
IB_EIN_SCHLOSS_ENTRIEGELN IB on unlock lock
INNENLICHT_AN_MEHRFACH_ZV: Interior lighst on several times
NEIGUGSGEBER : declination sensor
STANDRUECKSCHALTUNG : Condition Resetting at standing
TAGFAHRLICHT_ECE: Daylight lights
UMLUFT_MEMORY: recirculating air memory
WISCHERINTERVALL: wiper interval
KEY MEMORYS
BELUEFTUNGSKLAPPE_OEFF_1 : Ventilation Flap Oeff
Fernbedienung : Remote control
FUSSRAUMKLAPPE SCHLIES : Floor Space Flaps close
GERB AUT B ZUEND EIN : GERB automitc at ignition on
GEBLAESEBALKEN AUT MOD : Blower Bar Automatic Mode
GEBLAESEKORREKTUR : Blower Correction
KLAPPEN OEFFNEN : Flaps Opening
KLIMABETR BEI ZUEND EIN : airconditioning at ignition on
TAKTEN HIGH LOW ANZEIGE : Clocks High Low Announcement
Эта информация применима к Е38?
Antoha_samara вне форума
Эти 6 пользователя(ей) сказали Спасибо Antoha_samara за сообщение:
Arm44 (07.02.2014), BorisZ (16.09.2012), kostreame (04.02.2013), masterant (29.05.2010), Rus+ (02.12.2013), walentin (25.02.2016)
