Тема: BMW Inpa/Ediabas
Старый 31.10.2008, 23:37 #25
Сказал спасибо: 1,550
Поблагодарили 10,550 раз(а) в 1,957 сообщениях
  • Инструкция EDIABAS - ERROR REFERENCE (справочник по ошибкам BMW Ediabas). Описаны возможные ошибки, причины возникновения и способы их устранения. 73 страницы. Язык - английский.
Также по ошибкам можно почитать в этом мануале: тут.
IFH, Interface Handler:
IFH-0000: INTERNAL ERROR
IFH-0001: UART ERROR
IFH-0002: NO RESPONSE FROM INTERFACE
IFH-0003: DATATRANSMISSION TO INTERFACE DISTURBED
IFH-0004: ERROR IN INTERFACE COMMAND
IFH-0005: INTERNAL INTERFACE ERROR
IFH-0006: COMMAND NOT ACCEPTED
IFH-0007: WRONG UBATT
IFH-0008: CONTROLUNIT CONNECTION ERROR
IFH-0009: NO RESPONSE FROM CONTROLUNIT
IFH-0010: DATATRANSMISSION TO CONTROLUNIT DISTURBED
IFH-0011: UNKNOWN INTERFACE
IFH-0012: BUFFER OVERFLOW
IFH-0013: COMMAND NOT IMPLEMENTED
IFH-0014: CONCEPT NOT IMPLEMENTED
IFH-0015: UBATT ON/OFF ERROR
IFH-0016: IGNITION ON/OFF ERROR
IFH-0017: INTERFACE DEADLOCK ERROR
IFH-0018: INITIALIZATION ERROR
IFH-0019: DEVICE ACCESS ERROR
IFH-0020: DRIVER ERROR
IFH-0021: ILLEGAL PORT
IFH-0022: DRIVER STATUS ERROR
IFH-0023: INTERFACE STATUS ERROR
IFH-0024: CANCEL FAILED
IFH-0025: INTERFACE APPLICATION ERROR
IFH-0026: SIMULATION ERROR
IFH-0027: IFH NOT FOUND
IFH-0028: ILLEGAL IFH VERSION
IFH-0029: ACCESS DENIED
IFH-0030: TASK COMMUNICATION ERROR
IFH-0031: DATA OVERFLOW
IFH-0032: IGNITION IS OFF
IFH-0034: CONFIGURATION FILE NOT FOUND
IFH-0035: CONFIGURATION ERROR
IFH-0036: LOAD ERROR
IFH-0037: LOW UBATT
IFH-0038: INTERFACE COMMAND NOT IMPLEMENTED
IFH-0039: EDIC USER INTERFACE NOT FOUND
IFH-0040: ILLEGAL EDIC USER INTERFACE VERSION
IFH-0041: ILLEGAL PARAMETERS
IFH-0042: CARD INSTALLATION ERROR
IFH-0043: COMMUNICATION TRACE ERROR
IFH-0044: FLASH ERROR
IFH-0045: RUNBOARD ERROR
IFH-0046: EDIC API ACCESS ERROR
IFH-0047: PLUGIN ERROR
IFH-0048: PLUGIN FUNCTION ERROR
IFH-0049: CSS DEVICE DETECTION ERROR
IFH-0050: ENTRY IN DYNAMIC CONFIGURATION NOT FOUND
IFH-0051: INTERNAL DYNAMIC PROTOCOL ERROR
IFH-0052: CONCEPT NOT AVALIABLE
IFH-0053: ILLEGAL CONCEPT ID
IFH-0054: ILLEGAL FUNCTION PARAMETER
IFH-0055: CANNOT LOAD PROTOCOL TABLES
IFH-0056: ILLEGAL CHANNEL
IFH-0057: ERROR READ DIGITAL INPUTS
IFH-0058: ERROR SET DIGITAL OUTPUTS
IFH-0059: ERROR READ ANALOG INPUTS
BIP, BEST Interpreter:
BIP-0000: INTERNAL ERROR
BIP-0001: OUT OF RANGE
BIP-0002: IFH FUNCTION ERROR
BIP-0003: OBJECT FILE ERROR
BIP-0004: ILLEGAL OPCODE
BIP-0005: STACK OVERFLOW
BIP-0006: BEST FILE ERROR
BIP-0007: DIVISION BY ZERO
BIP-0008: BEST BREAK
BIP-0009: BEST VERSION ERROR
BIP-0010: CONSTANT DATA ACCESS ERROR
BIP-0011: REAL ERROR
BIP-0012: PLUG IN NOT FOUND
BIP-0013: PLUG IN ERROR
BIP-0014: PLUG IN VERSION ERROR
BIP-0015: PLUG IN STACK ERROR
BIP-0016: PLUG IN FUNCTION NOT FOUND
SYS, sequence control:
SYS-0000: INTERNAL ERROR
SYS-0001: ILLEGAL FUNCTION
SYS-0002: ECU OBJECT FILE NOT FOUND
SYS-0003: ECU OBJECT FILE ERROR
SYS-0004: ILLEGAL FORMAT OF ECU OBJECT FILE
SYS-0005: OBJECT FILE NOT FOUND
SYS-0006: GROUP OBJECT FILE ERROR
SYS-0007: ILLEGAL FORMAT OF GROUP OBJECT FILE
SYS-0008: JOB NOT FOUND
SYS-0009: NO INITIALIZATION JOB
SYS-0010: INITIALIZATION ERROR
SYS-0011: NO IDENTIFICATION JOB
SYS-0012: IDENTIFICATION ERROR
SYS-0013: UNEXPECTED RESULT
SYS-0014: ILLEGAL FORMAT
SYS-0015: TASK COMMUNICATION ERROR
SYS-0016: ILLEGAL CONFIGURATION
SYS-0018: END JOB ERROR
SYS-0019: TIMER ERROR
SYS-0020: BASE OBJECT FILE NOT FOUND
SYS-0021: BASE OBJECT FILE ERROR
SYS-0022: ILLEGAL FORMAT OF BASE OBJECT FILE
SYS-0023: PASSWORD ERROR
SYS-0024: ILLEGAL PASSWORD
API, Application Programming Interface:
API-0000: INTERNAL ERROR
API-0001: USER BREAK
API-0002: MEMORY ALLOCATION ERROR
API-0003: RESULT SETS OVERFLOW
API-0004: RESULTS OVERFLOW
API-0005: ILLEGAL RESULT FORMAT
API-0006: ACCESS DENIED
API-0007: INCORRECT CONFIGURATION FILE
API-0008: TASK COMMUNICATION ERROR
API-0009: EDIABAS NOT FOUND
API-0010: ILLEGAL EDIABAS VERSION
API-0011: ILLEGAL ECU PATH
API-0012: SIGNAL SERVER NOT FOUND
API-0013: INITIALIZATION ERROR
API-0014: RESULT NOT FOUND
API-0015: HOST COMMUNICATION ERROR
Network:
NET-0000: INTERNAL ERROR
NET-0001: UNKNOWN ERROR
NET-0002: ILLEGAL VERSION
NET-0003: INITIALIZATION ERROR
NET-0004: ILLEGAL CALL
NET-0005: NO SUPPORT
NET-0006: ACCESS DENIED
NET-0007:SYSTEM ERROR
NET-0008: NETWORK ERROR
NET-0009: TIMEOUT
NET-0010: BUFFER OVERFLOW
NET-0011: ALREADY CONNECTED
NET-0012: NO CONNECTION
NET-0013: CONNECTION DISTURBED
NET-0014: CONNECTION ABORTED
NET-0015: HOST NOT FOUND
NET-0016: HOST ERROR
NET-0017: PROTOCOL NOT AVAILABLE
NET-0018: UNKNOWN PROTOCOL
NET-0019: UNKNOWN SERVICE
NET-0020: UNKNOWN HOST
NET-0021: SERVER NOT FOUND
NET-0022: SECURITY ERROR
Applikation:
RUN-0000
RUN-0099
Содержание:
1. Revision history........................................... ..........................................3
2. Introduction...................................... .................................................. ....4
2.1. About this manual............................................ ........................4
2.2. Notational conventions....................................... .....................4
2.3. Special features, terms, acronyms.......................................... 5
3. General Information....................................... ........................................6
3.1. Error symbol and error code.............................................. ......6
3.2. Message and output of an error............................................. .6
3.3. How errors affect program execution......................................7
4. List of errors............................................ ...............................................8
4.1. IFH, Interface Handler........................................... ..................9
4.2. Runtime system............................................ ...................................34
4.2.1. BIP, BEST Interpreter....................................... ....................34
4.2.2. SYS, sequence control........................................... ..............41
4.3. API, Application Programming Interface......................................... 55
4.4. Network........................................... ........................................64
4.5. Applikation....................................... ........................................72
A. References........................................ .................................................. ....73
Пароль на открытие: www.bmwpost.ru
Тип файла: pdf www.bmwpost.ru-EDIABAS-ERRORS.pdf (420.0 Кб, 1839 просмотров)
Эти 8 пользователя(ей) сказали Спасибо Tyler за сообщение:
B1MMER (18.03.2013), BadgerBMW (22.09.2019), beastia (08.11.2013), sem911 (10.04.2014), SergeE46 (31.10.2013), Zeke (20.03.2013), Zexerlt (24.06.2014), Азиат (30.05.2013)
