17.10.2012, 01:14
#1 |
Сказал спасибо: 1,550
Поблагодарили 10,551 раз(а) в 1,957 сообщениях
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки | установка держателя для iphone (+ протяжка кабеля до приборки)
BMW F20 установка держателя для iphone (+ протяжка USB-кабеля из подлокотника до приборки) Необходимое:- Dashboard mount http://www.dashmount.co.uk/index.php...11i-Drive.html
- Phone mount (attaches to dashmount and holds phone) http://www.brodit.com/product.html?id=514164
- STAR T20 Screwdriver
Инструкция: - Шаг 1: Снимите вентиляционные решетки на панели
In this step, which is not as easy as a certain youtube video would suggest, we remove the center console vents. I did this by gripping the top right of the vent and getting my fingers under and unsnapping it, then i ran my fingers along to unsnap the left hand side. As seen below:
I then ran my fingers down from the leftside to finally unclip the vents:
At this point you can safely rest the vents on the centre console, it wont damage or scratch anything - Step 2: Remove the passenger side T20 (STAR) screw
Below you can see the screw which needs removing, this was simple, although a little effort was required- so make sure you use the correct bit, or you'll bald the head. - Step 3: Insert the dashboad mount
At this stage, i was a little worried as i couldnt figure out how to get the mount in. Turns out you simply need to slide it down between the dashboard and the CD unit as shown in the image below. ensure you align the screw hole with the screw hole in the dash - Step 4: Reassemble
Reassemble by screwing the T20 screw back in (nice and tight so everything comes together), and snap the vents back onto the dash - Step 5: Attach your chosen phone bracket
I used my brodit dock from my previous car, but you can attach whatever you wish. Any brodit dock works with this solution. The great thing about brodits is that its on a cylinder adjustable- so it can be rotated any direction to suit your needs - Step 5: Admire work
Congratulations, you now have a convenient way to access your phone. I'll post up how i routed my USB cable to the arm rest, if i ever get around to it:
Чат по кодированию, программированию, дооснащению BMW в Telegram: https://t.me/bmwpostforum BMW INPA | BMW ICOM | BMW Scanner | Ключи BMW | BMW CAN filter (cic retrofit adapter) | Отключение BMW EGR / DPF | Ноутбуки для диагностики Автосканеры, автодиагностика Сканеры для диагностики BMW Инструкции, мануалы к БМВ бесплатно BMW & MINI: TIS, ЕТК, ЕТМ, KSD, WDS, DIS, EBA и другие полезные программы |
