Старый 03.02.2009, 22:23 #6
Сказал спасибо: 1,550
Поблагодарили 10,551 раз(а) в 1,957 сообщениях
Модельные года - чем различаются e38:
1995
First year of the E38 7 series. Important: if you are considering the 1995 E38 with the V8, please look here first:
Nikasil Engine FAQ
What's wrong with the 1995 V8's?
1996
New 4.4 liter engine. Horsepower remained the same but torque went up from 295@4500 rpm to 310@3900 rpm. Standard steel sunroof changed, glass moon roof instead. (No 740i, just the 740iL and 750iL.)
1997
Side impact airbags standard for front seat passengers. Navigation system became available but fitted into few cars.
1998
DSC became available. HPS head airbags also standard and rear-seat side airbags optional. Navigation system more available. New AC control panel as well (although this was retrofitted to many pre-98 cars).
1999
Mild face-lift with scalloped headlights, crystallized tail lamps, door scoop illumination, and chrome strip on the trunk. The 4.4 liter engine receives VANOS variable valve timing and torque rises from 310 to 324. Updated side skirts without the round hole plugs for the jack. Sport package consisting of 18-inch rims, blackout trim, lower gear ratio, and vavona redwood interior trim became available on the 740i.
Note, 1999 model year had a shorter production period, from 9/98 to 2/99.
2000
Build dates: 3/99 to 2/00.
Features as standard that were options before. Xenon lights, rain sensing wipers, headlight washer nozzles, Navigation, DSP stereo with cassette in the dash and 6 disk changer in the trunk. Sport package became available on 740iL/750iL models, sans the lower gearing.
2001
Build dates: 3/00-8/00 had regular screen NAV.
Build dates: 9/00-7/01 had wide screen NAV.
For the last year, they added body colored side skirts, and front and rear air dams (all were black until 2001) and crystal clear turn signals. Features as standard that were options before, StarTac phone with mayday system, 16 way comfort seats.
