Старый 07.01.2010, 00:20 #2
Сказал спасибо: 1,550
Поблагодарили 10,550 раз(а) в 1,957 сообщениях
  • Руководство по КПП BMW (различные модели). Язык - английский. Формат: .pdf, 39 страниц.
Содержание:
Transmission Fundamentals
Standard/Automatic Transmission Comparison ............................... 3
Hydraulic Transmission vs. Electro-Hydraulic Transmission .......... 4
Transmission Identification .................................................. ............... 5
Transmission Hydraulics .................................................. ................... 6
Transmission Fluid Application ---------------------------------------- 7
Torque Converter .................................................. ............................... 8
Torque Converter Clutch .................................................. .................. 10
Transmission Oil Pump .................................................. ......................12
Crescent Type Pump .................................................. ......................... 12
Vane Type Pump .................................................. ............................... 13
Hydraulic Control Components .................................................. ....... 14
Electro-Hydraulic Valve Body .................................................. ............. 14
Shift Valves .................................................. ........................................ 15
Pressure Regulation .................................................. .......................... 16
Apply Components .................................................. ............................ 18
Multi-Plate Clutches and Brakes .................................................. ......... 18
Band Brakes .................................................. ........................................20
One-Way Clutches .................................................. .............................. 21
Planetary Gear Set .................................................. ............................. 22
Compound Planetary Gear Sets .................................................. ....... 23
Simpson Gear Set .................................................. ................................ 23
Ravigneaux Gear Set .................................................. .............................24
Wilson Gear Set .................................................. .....................................25
Lepeletier Gear Set .................................................. ................................26
Planetary Gear Set Operation .................................................. ............27
Shift Control .................................................. ........................................34
Transmission Control Module .................................................. ........... 38
Review Questions .................................................. ...............................39
Table of Contents
Тип файла: rar Transmission_Fundamentals.rar (1.61 Мб, 442 просмотров)
Тип файла: rar Tech BMW Transm - часть 2.rar (655.4 Кб, 421 просмотров)
Эти 6 пользователя(ей) сказали Спасибо Tyler за сообщение:
askoldov (31.10.2011), bmw-777 (13.05.2010), il730 (13.12.2010), Mad-Mike (06.12.2015), zalimhan74 (23.04.2015), ЕкатеринаE46 (10.12.2020)
