Тема: Троит M52TU
Старый 20.05.2014, 08:53 #5
Аватар для sky_Nick
Авто: 328 (T46)
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 05/20/14 10:39:05 ECU: MS420DS0 JobStatus: OKAY Variant: MS420DS0 -------------------------------------------------------------
RESULT: 7 errors in error memory ! -------------------------------------------------------------
203 lambda control Bank 2 control block
Error frequency : 3 Logistic counter: 40
Engine speed 704.00 1/min temperature cooling water 98.25 Grad C load 76.26 mg/Hub lambda probe voltage control probe Bank 0.01 V appear before (rel.) 1.40 h
Abweichung fett CARB-Fehler Fehler nach Entprellung gespeichert Fehler momentan nicht vorhanden sporadischer Fehler
Errorcode: CB B1 03 28 16 C3 0E 02 FC 33 -------------------------------------------------------------
202 lambda control Bank 1 control block
Errorcode: CA B1 03 28 16 C3 0E 02 FC 33 -------------------------------------------------------------
227 lambda contol tolerance Bank 1 to big
Error frequency : 4 Logistic counter: 40
Engine speed 704.00 1/min load 81.71 mg/Hub temperature cooling water 98.25 Grad C lambda contol tolerance Bank 1 -0.00 % appear before (rel.) 1.40 h
Abweichung fett CARB-Fehler Fehler nach Entprellung gespeichert Fehler momentan vorhanden sporadischer Fehler
Errorcode: E3 F1 04 28 16 0F C3 80 FC 33 -------------------------------------------------------------
228 lambda contol tolerance Bank 2 to big
Engine speed 704.00 1/min load 81.71 mg/Hub temperature cooling water 98.25 Grad C lambda contol tolerance Bank 2 -0.00 % appear before (rel.) 1.40 h
Errorcode: E4 F1 04 28 16 0F C3 80 FC 33 -------------------------------------------------------------
151 Signal Lambda probe before-Kat Bank 1 min value less then limit
Engine speed 736.00 1/min load 103.49 mg/Hub temperature cooling water 98.25 Grad C lambda probe voltage control probe Bank 0.02 V appear before (rel.) 0.90 h
Errorcode: 97 B2 04 28 17 13 C3 04 FC 38 -------------------------------------------------------------
154 Signal Lambda probe before-Kat Bank 2 min value less then limit
Errorcode: 9A B2 04 28 17 13 C3 04 FC 38 -------------------------------------------------------------
103 control-VANOS end position intake-camshaft
Error frequency : 1 Logistic counter: 40
camshaft rough value intake 129.38 Grad KW
camshaft referenz intake 129.00 Grad KW Engine speed 960.00 1/min oel temperature 29.22 Grad C appear before (rel.) 0.90 h
Adaptionswert ausserhalb der Toleranz CARB-Fehler Fehler nach Entprellung gespeichert Fehler momentan nicht vorhanden sporadischer Fehler
Errorcode: 67 B8 01 28 B9 B8 1E 61 FC 38 ================================================== ===========
Может все дело в датчике распредвала ? 103 control-VANOS end position intake-camshaft
sky_Nick вне форума   Ответить с цитированием
