Старый 06.04.2015, 01:25 #2
Сказал спасибо: 1,550
Поблагодарили 10,545 раз(а) в 1,956 сообщениях
  • Оригинальная инструкция по дооснащению BMW Head-Up Screen Retrofit
Для автомобилей:
BMW 1 серии (E81, E82, E87, E88, F20, F21)
BMW 2 серии (F22, F23, F45, F46)
BMW 3 серии (E90, E91, E92, E93, F30, F31, F34, F35)
BMW 4 серии (F32, F33, F36)
BMW 5 серии (F10, F11)
BMW X1 (E84)
BMW X3 (F25)
BMW X4 (F26)
Номер:
62 30 2 361 627 BMW Head-Up Screen retrofit kit
Содержание:
Section Page
1. Parts list for retrofit kit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
2. Preparatory work . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
3. Retrofit wiring harness connection diagram (E81, E82, E84, E87, E88, E90, E91, E92, E93 cars only) . . 6
4. Retrofit wiring diagram connection diagram
(F20, F21, F22, F23, F30, F31, F32, F33, F34, F35, F36 cars only) . . . . . . . . . . . . . . . . . 7
5. Retrofit wiring harness connection diagram (F10, F11, F25, F26 cars only) . . . . . . . . . 8
6. Retrofit wiring harness connection diagram (F45, F46 cars only) . .. . . . . . 9
7. Installation and cabling diagram
(E81, E82, E84, E87, E88, E90, E91, E92, E93 cars only) . . . . . . . . . 10
8. Installation and cabling diagram
(F20, F21, F22, F23, F30, F31, F32, F33, F34, F35, F36 cars only) . . . . . . . . . 11
9. Installation and cabling diagram (F25, F26 cars only) . . . . . . . . . . . . . . . . . 12
10. Installation and cabling diagram (F10, F11 cars only) .. . . . . . . . . . . . . . . . . . . 13
11. Installation and cabling diagram (F45, F46 cars only) . . . . . . . . . . . . . . . . . . . 14
12.Routing and connecting the retrofit wiring harness
(E81, E82, E84, E87, E88, E90, E91, E92, E93 cars only) . . . . . . . . . . . . 15
13.Routing and connecting the retrofit wiring harness
(F20, F21, F22, F23, F30, F31, F32, F33, F34, F35, F36 cars only) . . . . . . . . . . . . . 17
14.Routing and connecting the retrofit wiring harness (F10, F11, F25, F26 cars only) .. . . . 19
15.Routing and connecting the retrofit wiring harness (F45, F46 cars only) . . . . . . . . . . . 20
16. Installing the Head-Up Screen . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
17. Concluding work and coding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25
18.Wiring diagram (E81, E82, E84, E87, E88, E90, E91, E92, E93 cars only) . . . . . . . . . 26
19.Wiring diagram (F20, F21, F22, F23, F30, F31, F32, F33, F34, F35, F36 cars only) . . . . 27
20.Wiring diagram (F10, F11, F25, F26 cars only) . . . . . . . . . . . . . . . . 28
21.Wiring diagram (F45, F46 cars only). . . . . . . . . . . . . . . . . . . . . . . 29
Тип файла: pdf www.bmwpost.ru-1411-EDoc559870730-EBA-01292405307-HeadupDisplay.pdf (192.7 Кб, 217 просмотров)
