Старый 30.12.2016, 11:14 #2
Авто: X3 E83 N52N 2.5si 2010г
Артур, добрый день. Нужна ваша помощь.
X3 E83 N52N 2.5si 2010г. м.Братиславска
Не заводится.
Ошибка:
002AB4 DME, internal error: RAM checksum
и еще немного
$error location No.: 11908
$error location text: 2E84 electrical coolant pump, communication
57042E8464040000FF2829443C8F02872946568802862D7600 200074
Error: 1(4) No.: 11908 2E84 electrical coolant pump, communication frequency: 255
error type: 4 (4209 ) communication error
Readines Flag: (16 ) Test conditions fulfilled
errorstatus: (35 ) failure presently available, OBDon-board diagnosis debounced
MIL - Status: (48) failure does not cause warning lamp show light (MIL)
P-Code: F_LZ: 40
environment text / entry 93104 km(n.) 84528 km(2.) 84512 km(1.)
Engine speed 0.00 rpm 2752.00 rpm 1920.00 rpm
coolant temperature OBD -8.00 °C 96.00 °C 103.00 °C
status motor control ENG_STOP SYN_ENG_IGK_ON SYN_ENG_IGK_ON
voltage Kl. 87 11.78 V 13.61 V 13.71 V
__________________________________________________ _________
2E84 Электрический насос охлаждающей жидкости, связь
$error location No.: 10882
$error location text: 2A82 inlet-Vanos variable cam control test
57042A828800001201082CF520933F43000000000000000000 000000
Error: 2(4) No.: 10882 2A82 inlet-Vanos variable cam control test frequency: 1
error type: 8 (4168 ) sluggish, mechanically stuck
errorstatus: (32 ) failure presently not available, OBDon-board diagnosis not debounced
MIL - Status: (49) failure would cause warning lamp show light (MIL)
P-Code: P0012 'A' Camshaft Position - Timing Over-Retarded (Bank 1) F_LZ: 8
environment text / entry 92072 km(1.)
Engine speed 1024.00 rpm
camshaft inlet 115.12 °CRK
camshaft inlet nominal value 83.62 °CRK
Engine temperature 2.25 °C
2А82 Магнитный клапан VANOS впускной распределительный вал
$error location No.: 10912
$error location text: 2AA0 camshaft sensor inlet, signal
57042AA08100034001282D760724016A000000000000000000 000000
Error: 3(4) No.: 10912 2AA0 camshaft sensor inlet, signal frequency: 1
error type: 1 (4169 ) signal missing
P-Code: P0340 Camshaft Position Sensor 'A' Circuit (Bank 1 or Single Sensor) F_LZ: 40
environment text / entry 93104 km(1.)
Engine speed 224.00 rpm
( engine ) - oil temperature -4.00 °C
motor status ST
voltage Kl. 87 10.77 V
2AA0 Позиционный датчик распределительного вала впускной распределительный вал
$error location No.: 10913
$error location text: 2AA1 camshaft sensor outlet, signal
57042AA18100036501282D760724016A000000000000000000 000000
Error: 4(4) No.: 10913 2AA1 camshaft sensor outlet, signal frequency: 1
P-Code: P0365 Camshaft Position Sensor 'B' Circuit (Bank 1) F_LZ: 40
motor status ST
2AA1 Позиционный датчик распределительного вала выпускной распределительный вал
cheburka вне форума   Ответить с цитированием
