Тема: BMW Inpa/Ediabas
Старый 31.10.2008, 23:36 #11
Сказал спасибо: 1,550
Поблагодарили 10,545 раз(а) в 1,956 сообщениях
  • Мануал по NFS (New Flash System). System Documentation. Формат PDF. 60 страниц. Автор: Georg Rauter, BMW AG.
Содержание:
1 Overview.......................................... .................................................. ...5
1.1 Function Overview.......................................... .................................................5
1.2 CASCADE Operation......................................... .............................................5
1.3 NFS Operating Modes............................................. ........................................5
1.3.1 Normal Flow (Pre-Series Vehicles)......................................... ....................................5
1.3.2 ZB_CHECK.......................................... .................................................. .....................7
1.3.3 Trailer Operation......................................... .................................................. ..............7
1.3.4 HO Mode.............................................. .................................................. ......................7
1.3.5 Emergency Flashing.......................................... .................................................. ........7
1.3.6 Sample............................................ .................................................. ............................7
1.4 Multi-Channel Operation......................................... .......................................7
1.5 Multi Instance Operation......................................... .......................................8
1.6 Requirements...................................... .................................................. ............8
2 Installation...................................... .................................................. ....8
2.1 Installation from the GIS Server............................................ ........................8
2.2 Individualization................................. .................................................. ...........8
2.3 Documentation and Online Help.............................................. ......................9
2.4 Questions and Answers........................................... .........................................9
2.5 Contact Persons........................................... .................................................. ...9
3 Command Line.............................................. .....................................10
3.1 Call-up from CASCADE........................................... ....................................10
4 Operation......................................... .................................................. .11
4.1 Main Window............................................ .................................................. ...11
4.1.1 Elements of the Main Window............................................ .....................................11
4.1.2 Traffic Light............................................. .................................................. ................13
4.1.3 Signal Lights............................................ .................................................. .................13
4.1.4 Operating Elements for Process Control........................................... ......................14
4.1.5 File Menu.............................................. .................................................. ....................14
4.1.6 Menu Extras............................................ .................................................. .................15
4.1.7 Emergency Flashing Menu.............................................. .........................................18
4.1.8 Configuration Menu.............................................. .................................................. ..18
4.1.9 TestMode Menu.............................................. .................................................. .........18
4.1.10 Help Menu.............................................. .................................................. ..................20
4.2 Additional Windows........................................... ............................................20
4.2.1 Display Window............................................ .................................................. ...........21
4.2.2 Selection Window............................................ .................................................. .........22
4.2.3 Message Dialog............................................ .................................................. .............23
4.2.4 Configuration dialog for trailermode....................................... ................................23
5 Program Flow.............................................. .......................................27
5.1 Rough Flow.............................................. .................................................. .....27
5.2 Partial Flow: Normal Flow.............................................. ..............................28
5.2.1 Detailed Flow – Determining Vehicle Data (Flash)........................................... .....29
5.2.2 Detailed Flow - Flashing.......................................... .................................................. 30
5.3 Partial Flow: CASCADE Run............................................... .......................31
5.4 Partial Flow: Emergency Flashing.......................................... .....................32
6 Logging (Trace)........................................... .......................................33
6.1 Programming Diary............................................. ..........................................33
6.2 Current Vehicle........................................... .................................................. .34
6.3 Programmable ZB Numbers........................................... ..............................38
6.4 Vehicle Orders............................................ .................................................. ..39
6.5 ID Data.............................................. .................................................. ............40
6.6 KMM Modification Plans............................................. .................................41
6.7 KMM Backup Modification Plans............................................. ...................42
6.8 Error Log............................................... .................................................. .......42
7 Configuration Files............................................. ...............................44
7.1 ANLAGE.INI........................................ .................................................. ........44
7.2 NFS.INI........................................... .................................................. ..............44
7.3 Multi Instance and Multi-Channel........................................... ....................50
7.3.1 Only One Instance.......................................... .................................................. .........50
7.3.2 Several Instances......................................... .................................................. .............51
7.3.3 Multi-Channel Operation......................................... .................................................5 1
7.3.4 Sample Configuration OBD.INI........................................... ....................................52
7.3.5 Sample Configuration REMOTE.INI........................................ ..............................52
8 Interfaces........................................ .................................................. ..53
8.1 CASCADE........................................... .................................................. .........53
8.2 EDIABAS........................................... .................................................. ...........54
8.3 Configuration Management (KMM)............................................. ...............54
8.4 WinKFP............................................ .................................................. ............54
8.5 Signal Lights............................................ .................................................. .....56
8.6 ECU SGBDs............................................. .................................................. .....57
9 Abbreviations and Glossary.......................................... ....................59
Тип файла: pdf www.bmwpost.ru_nfs.pdf (1.92 Мб, 1724 просмотров)
Эти 12 пользователя(ей) сказали Спасибо Tyler за сообщение:
Bavarian Aviation (16.11.2017), Dep (14.08.2010), eric (21.03.2013), keyway (11.09.2011), Petrivsky (14.12.2010), pveasb (27.12.2012), shimas7 (12.04.2015), skipex (02.06.2011), viktor.zackolupin (23.02.2011), zalimhan74 (08.12.2014), Zeke (28.06.2010), Zexerlt (24.06.2014)
