Старый 23.11.2010, 15:43 #31
Сказал спасибо: 1,550
Поблагодарили 10,551 раз(а) в 1,957 сообщениях
  • Мануал АКПП ZF 6HP26 / 6HP28. 37 страниц. Техническая информация + каталог деталей. Язык - английский.
Содержание:
Technical Information
Torque, Gear Ratio & Weight______________________________________2
Oil Capacity__________________________________________ _________2
6HP26 / 6HP28 Lubricants________________________________________ 2
6HP26 / 6HP28 Technical Literature________________________________2
6HP26 / 6HP28 General Transmission Oil Filling Procedure______________3-7
How To Use This Catalog_________________________________________8
Type Plate Information_______________________________________ ____9
Spare Parts
Gearbox Housing Group__________________________________________10
Torque Converter Group_________________________________________11
Oil Supply Group_____________________________________________ __12
Front Planetary Group___________________________________________13
Rear Planetary Group____________________________________________1 4
Coupling A Group_____________________________________________ __15
Coupling B Group_____________________________________________ __16
Coupling C Group_____________________________________________ __17
Coupling D Group_____________________________________________ __18
Coupling E Group_____________________________________________ __19
Output Group_____________________________________________ _____20
Filter Group_____________________________________________ _______21
Mechatronic Group_____________________________________________ _22
Gear Shift System E-Shift Group___________________________________23
Gear Shift System M-Shift Group___________________________________24
Parking Lock Group_____________________________________________ 25
Selective Shims, Snap Rings, Steel Plate & Kits Content
Selective Shims_____________________________________________ ___26
Selective Snap Rings____________________________________________2 7-28
Selective Steel Plate_____________________________________________ 29
Kits Content___________________________________________ ________30-35
Тип файла: pdf www.bmwpost.ru_6HP26-28_Catalog.pdf (1.42 Мб, 954 просмотров)
Эти 6 пользователя(ей) сказали Спасибо Tyler за сообщение:
andrey75r (07.09.2011), eric (04.11.2012), Gaj2 (18.09.2015), killshev (26.04.2012), maxuss (09.03.2012), wadim_2011 (02.08.2011)
