Старый 25.11.2010, 14:21 #4
Сказал спасибо: 12
Поблагодарили 27 раз(а) в 16 сообщениях
Авто: bmw 518i e34
Вот что нашел:
OBC
pin1: violet/green/yellow, alarm system
pin10: black/green, starter
pin6: + from fuse F17
pin9: + from fuse F20 (red/yellow)
pin8: + from fuse F1
pin22: grey/red, light switch
pin25: yellow/red, turn signal switch
pin3: white/yellow, diagnostics
pin16: white/violet, diagnostics
pin14: white/grey, instrument cluster
pin7: black/white, instrument cluster
pin4: ground
pin5: blue/red/yellow, temp sensor
pin20: black/red/yellow, pre-ventilation
pin21: black/white, pre-ventilation
pin23: violet/white/yellow, alarm system
pin17: red/grey/yellow, alarm system
pin26: black/red/yellow, fuel tank level sensor
pin12: brown/violet, fuel tank level sensor
pin11: white/black, DME
pin24: black/violet, DME
pin19: white/red, chimes
pin18: white/blue, chimes
pin15: white/brown, radio
pin2: blue/brown/yellow, radio
Никто не подскажет кто такие diagnostics и instrument cluster. white/black DME искать в мозговой косе?
rawmeathunter вне форума   Ответить с цитированием
