Старый 25.11.2010, 15:24 #35
Сказал спасибо: 1,550
Поблагодарили 10,551 раз(а) в 1,957 сообщениях
  • Мануал АКПП ZF 6HP19 / 6HP21. 31 страница. Техническая информация + каталог деталей. Язык - английский.
Содержание:
Technical Information
Torque, Gear Ratio & Weight______________________________________2
Oil Capacity__________________________________________ _________2
6HP19 / 6HP21 Lubricants________________________________________ 2
6HP19 / 6HP21 Technical Literature________________________________2
6HP19 / 6HP21 General Transmission Oil Filling Procedure______________3-5
How To Use This Catalog_________________________________________6
Type Plate Information_______________________________________ ____7
6HP19 1071 010 XXX / 6HP21 1071 030 XXX
Spare Parts
Gearbox Housing Group__________________________________________8
Torque Converter Group_________________________________________9
Oil Supply Group_____________________________________________ __10
Front Planetary Group___________________________________________11
Rear Planetary Group____________________________________________1 2
Coupling A Group_____________________________________________ __13
Coupling B Group_____________________________________________ _ 14
Coupling C Group_____________________________________________ _ 15
Coupling D Group_____________________________________________ _ 16
Coupling E Group_____________________________________________ _ 17
Output Group_____________________________________________ _____18
Filter Group_____________________________________________ _______19
Mechatronic Group_____________________________________________ _20
Gear Shift System E-Shift Group___________________________________21
Gear Shift System M-Shift Group___________________________________22
Parking Lock Group____________________________________________ 23
Selective Shims, Snap Rings & Kits Content
Selective Shims_____________________________________________ __ 24
Selective Snap Rings____________________________________________2 5-26
Kits Content___________________________________________ ________27- 29
Тип файла: pdf www.bmwpost.ru_ZF_6HP_19-21.pdf (935.2 Кб, 529 просмотров)
Тип файла: pdf www.bmwpost.ru_zf6hp19.pdf (193.1 Кб, 396 просмотров)
Эти 4 пользователя(ей) сказали Спасибо Tyler за сообщение:
andrey75r (07.09.2011), deso_bg (22.02.2019), eric (04.11.2012), wadim_2011 (02.08.2011)
