Системы подвесок BMW Вложений: 1
Definitions of terms Relationships between axle geometry parameters Axle kinematics Faults and their effects |
Вложений: 1
Purpose of the System .................................................. ...................... 3 Basic Suspension Geometry .................................................. ............. 4 Caster .................................................. .................................................4 Camber .................................................. ...............................................5 Toe .................................................. .................................................. ....6 Steering Roll Radius .................................................. ............................7 Steering Axis Inclination .................................................. ..................... .8 Toe-out on Turns .................................................. .................................9 Geometric Axis .................................................. ...................................10 Suspension Systems .................................................. ..........................11 Single Joint Front Suspension .................................................. .......... ..11 Double Pivot Front Suspension .................................................. .......... 14 Rear Suspension Systems .................................................. ................ 16 Semi-Trailing Arm .................................................. ................................17 Semi-Trailing Arm with “Track Link” .................................................. .....18 Central “C” Link .................................................. ..................................19 Multi-Link Suspensions .................................................. .......................22 Alignment Procedures .................................................. ...................... 28 Vehicle Inspection .................................................. ...............................29 Ride Height Measurement .................................................. ... ...............30 Identification of Suspension .................................................. ....... .........32 Vehicle Loading .................................................. .......................... ........34 Alignment Specifications .................................................. .....................36 Alignment Checklist .................................................. ................... .........38 Alignment Worksheets .................................................. ........................39 Review Questions .................................................. ...............................40 Скачать бесплатно - в приложенном файле. |
Часовой пояс GMT +3, время: 12:22. |
