Мануалы по ремонту и регулировке АКПП и МКПП ZF
Like Tree5Likes
Старый 20.09.2009, 19:52 #11
Мануал по АКПП ZF 5HP19FL. 50 страниц. .pdf
Содержание:
5HP19FL Transmission Overview (North American Applications)
Make / Model / Model Year 02
5HP19FL Technical Information
Torque, Gear Ratio & Weight 03
Transmission Oil Reference Guide 03
5HP19FL Lubrications 03
5HP19FL Technical Literature 03
5HP19FL General Transmission Oil Filling Procedure 04
5HP19FL General Differential Oil Filling Procedure 06
5HP19FL Spare Parts
How To Use This Catalog 07
Gearbox Housing Group 08
Oil Sump Group 10
Oil Supply Group 11
Converter Group 13
Planetary Drive Groups 14
Front Axle Differential Group 16
Front Axle Output Group 18
Clutch Pack Groups 19
5HP19FL Valve Body
Duct Plate Group 25
Valve Housing Groups 29
5HP19FL Selective Shims, Snap Rings & Kit Content
5HP19FL Selective Shims & Snap Rings 37
5HP19FL Kit Content 44
Miscellaneous
Quotation / Order Form 48
Notes 49
Тип файла: pdf www.bmwpost.ru_5HP19FL.pdf (1.09 Мб, 319 просмотров)
andrey75r (07.09.2011), atanas yanchev (27.08.2014), BAM161 (23.10.2010), Mik78 (12.07.2010), XCommandeRX (10.01.2013)
Старый 20.09.2009, 20:01 #12
Мануал по АКПП ZF 5HP19FLA. 59 страниц. .pdf
Содержание:
5HP19FLA Transmission Overview (North American Applications)
5HP19FLA Technical Information
5HP19FLA Lubrications 03
5HP19FLA Technical Literature 03
5HP19FLA General Transmission Oil Filling Procedure 04
5HP19FLA General Differential Oil Filling Procedure 06
5HP19FLA General Transfer Case Oil Filling Procedure 07
5HP19FLA Spare Parts
How To Use This Catalog 08
Gearbox Housing Group 09
Oil Sump Group 12
Oil Supply Group 13
Converter Group 15
Planetary Drive Groups 16
Front Axle Differential Group 18
Rear Axle Output Group 21
Front Axle Output Group 23
Internal Differential Lock Group 24
Clutch Pack Groups 25
5HP19FLA Valve Body
Duct Plate Group 31
Valve Housing Groups 35
5HP19FLA Selective Shims, Snap Rings & Kit Content
5HP19FLA Selective Shims & Snap Rings 46
5HP19FLA Kit Content 53
Miscellaneous
Quotation / Order Form 57
Notes 58
Тип файла: pdf www.bmwpost.ru_5HP19FLA.pdf (1.17 Мб, 213 просмотров)
andrey75r (07.09.2011), atanas yanchev (27.08.2014), BAM161 (23.10.2010), Mik78 (12.07.2010), КРУГЛОВ (21.05.2015)
Старый 20.09.2009, 20:04 #13
Мануал по АКПП ZF 5HP24. 43 страницы. .pdf
Содержание:
5HP24 Transmission Overview (North American Applications)
5HP24 Technical Information
5HP24 Lubrications 03
5HP24 Technical Literature 03
5HP24 General Transmission Oil Filling Procedure 04
5HP24 Spare Parts
How To Use This Catalog 06
Gearbox Housing Group 07
Input Group 10
Oil Sump Group 11
Oil Supply Group 12
Output Group 13
Converter Group 15
Parking Lock Group 16
Brake Group 17
Planetary Drive Groups 18
Clutch Pack Groups 20
5HP24 Valve Body
Duct Plate Group 27
5HP24 Selective Shims, Snap Rings & Kit Content
5HP24 Selective Shims & Snap Rings 35
5HP24 Kit Content 38
Miscellaneous
Quotation / Order Form 41
Notes 42
Тип файла: pdf www.bmwpost.ru_5HP24.pdf (842.9 Кб, 345 просмотров)
andrey75r (07.09.2011), BAM161 (23.10.2010), bratan (27.10.2014), Mik78 (12.07.2010), Игорь Чита (16.05.2014), Сергей2205 (17.02.2014)
Старый 20.09.2009, 20:06 #14
Мануал по АКПП ZF 5HP24A. 51 страница. .pdf
Содержание:
5HP24A Transmission Overview (North American Applications)
5HP24A Technical Information
5HP24A Lubrications 03
5HP24A Technical Literature 03
5HP24A General Transmission Oil Filling Procedure 04
5HP24A General Differential Oil Filling Procedure 06
5HP24A General Transfer Case Oil Filling Procedure 07
5HP24A Spare Parts
Input Group 11
Oil Sump Group 12
Oil Supply Group 13
Converter Group 14
Parking Lock Group 15
Brake Group 16
Planetary Drive Groups 17
Front Axle Differential Group 19
Internal Differential Lock Group 25
Clutch Pack Groups 26
5HP24A Valve Body
Duct Plate Group 32
Valve Housing Groups 34
5HP24A Selective Shims, Snap Rings & Kit Content
5HP24A Selective Shims & Snap Rings 39
5HP24A Kit Content 45
Miscellaneous
Quotation / Order Form 49
Notes 50
Тип файла: pdf www.bmwpost.ru_5HP24A.pdf (1.04 Мб, 207 просмотров)
Старый 20.09.2009, 20:08 #15
Мануал по АКПП ZF 5HP30. 43 страницы. .pdf
Содержание:
5HP30 Transmission Overview (North American Applications)
5HP30 Technical Information
5HP30 Lubrications 03
5HP30 Technical Literature 03
5HP30 General Transmission Oil Filling Procedure 04
5HP30 Spare Parts
Input Group 10
Oil Sump Group 11
Oil Supply Group 12
Output Group 13
Converter Group 14
Clutch Pack Groups 18
5HP30 Valve Body
Duct Plate Group 25
Valve Housing Groups 27
5HP30 Selective Shims, Snap Rings & Kit Content
5HP30 Selective Shims & Snap Rings 32
5HP30 Kit Content 34
5HP30 Torque Converter Spare Parts & Kits
5HP30 Torque Converter Spare Parts 40
5HP30 Torque Converter Kits 40
Miscellaneous
Notes 42
Тип файла: pdf www.bmwpost.ru_5HP30.pdf (971.8 Кб, 236 просмотров)
andrey75r (07.09.2011), BAM161 (23.10.2010), Catdiesel (18.03.2010), Mik78 (12.07.2010), stasau (12.09.2010)
Старый 18.06.2010, 23:58 #16
  • Мануал по АКПП ZF 4HP22/24. Устранение течи поддона картера АКПП. 2 страницы. Язык - английский.
Тип файла: pdf www.bmwpost.ru_4hp22-24.pdf (131.3 Кб, 152 просмотров)
BAM161 (23.10.2010), Mad-Mike (02.10.2017), Mik78 (12.07.2010)
Старый 20.09.2010, 23:09 #17
  • Ещё 1 мануал по диагностике АКПП ZF 4hp22. 6 страниц. Формат PDF.
Скачать бесплатно - в приложенном файле.
Тип файла: pdf www.bmwpost.ru_4hp22diagnose.pdf (340.3 Кб, 189 просмотров)
Старый 20.09.2010, 23:16 #18
  • DTC Summaries. Коды ошибок АКПП ZF 4HP24 E9 / AJ16 и возможные причины их появления. Формат PDF. 7 страниц.
Тип файла: pdf www.bmwpost.ru_bmw_4HP24_diag.pdf (27.4 Кб, 143 просмотров)
Kotofey (12.02.2015)
Старый 23.11.2010, 11:36 #19
  • Мануал АКПП BMW ZF-5HP19FL - PRELIMINARY INFORMATION. Формат PDF. 20 страниц. Язык - английский.
Тип файла: pdf www.bmwpost.ru_BMW_ZF-5HP-19FL.pdf (3.17 Мб, 147 просмотров)
Старый 23.11.2010, 12:14 #20
  • Мануал АКПП ZF 5HP19. Формат PDF. 6 страниц. Язык - английский.
Содержание:
Clutch and brake-clutch application chart
Solenoid application chart
Solenoid and sensor resistance chart
Internal wire schematic
MV 1,2 and 3 operation
EDS 2,3 and 4 operation
EDS-1 operation
Solenoid identification and locations
Shift Quadrant
Тип файла: pdf www.bmwpost.ru_ZF_5hp19.pdf (707.9 Кб, 173 просмотров)
Hook (22.09.2015), ломастер (26.12.2010)
4hp20, 4hp22, 5hp19, 5hp24, 5hp30, 6hp19, 6hp21, 6hp26, 6hp26x, 6hp28x, 6hp32, 8hp45, 8hp70
Мануалы по ремонту и регулировке АКПП GM Tyler Инструкции, Мануалы BMW 7 27.05.2013 00:23
Мануалы, инструкции, руководства на МКПП и АКПП BMW Tyler Инструкции, Мануалы BMW 2 08.02.2011 16:35
Часовой пояс GMT +3, время: 15:23.
