Мануалы по ремонту и регулировке АКПП и МКПП ZF
Like Tree5Likes
Старый 23.11.2010, 15:43 #31
  • Мануал АКПП ZF 6HP26 / 6HP28. 37 страниц. Техническая информация + каталог деталей. Язык - английский.
Содержание:
Technical Information
Torque, Gear Ratio & Weight______________________________________2
Oil Capacity__________________________________________ _________2
6HP26 / 6HP28 Lubricants________________________________________ 2
6HP26 / 6HP28 Technical Literature________________________________2
6HP26 / 6HP28 General Transmission Oil Filling Procedure______________3-7
How To Use This Catalog_________________________________________8
Type Plate Information_______________________________________ ____9
Spare Parts
Gearbox Housing Group__________________________________________10
Torque Converter Group_________________________________________11
Oil Supply Group_____________________________________________ __12
Front Planetary Group___________________________________________13
Rear Planetary Group____________________________________________1 4
Coupling A Group_____________________________________________ __15
Coupling B Group_____________________________________________ __16
Coupling C Group_____________________________________________ __17
Coupling D Group_____________________________________________ __18
Coupling E Group_____________________________________________ __19
Output Group_____________________________________________ _____20
Filter Group_____________________________________________ _______21
Mechatronic Group_____________________________________________ _22
Gear Shift System E-Shift Group___________________________________23
Gear Shift System M-Shift Group___________________________________24
Parking Lock Group_____________________________________________ 25
Selective Shims, Snap Rings, Steel Plate & Kits Content
Selective Shims_____________________________________________ ___26
Selective Snap Rings____________________________________________2 7-28
Selective Steel Plate_____________________________________________ 29
Kits Content___________________________________________ ________30-35
Тип файла: pdf www.bmwpost.ru_6HP26-28_Catalog.pdf (1.42 Мб, 966 просмотров)
andrey75r (07.09.2011), eric (04.11.2012), Gaj2 (18.09.2015), killshev (26.04.2012), maxuss (09.03.2012), wadim_2011 (02.08.2011)
Старый 23.11.2010, 16:06 #32
  • Презентация, содержащая много полезной информации по семейству АКПП ZF 6HP. 66 страниц. Язык - английский.
Business unit „Automatic transmissions“
The 6HP gearbox-family
Hints for the repairshop:
General hints
gearbox change
change of a mechatronic
change of a oilpan and filter
changing or adding oil
  • Небольшая статья по АКПП ZF 6HP. 4 страницы. Язык - английский.
Тип файла: pdf www.bmwpost.ru_ZF_Transmissions_with_Mechatronics.pdf (4.78 Мб, 738 просмотров)
Тип файла: pdf zf_6hp_article.pdf (244.9 Кб, 517 просмотров)
deso_bg (22.02.2019), eric (04.11.2012), Gaj2 (18.09.2015), killshev (26.04.2012)
Старый 23.11.2010, 16:14 #33
  • Причины течи масла и способы их устранения на АКПП 6HP19/21 и 6HP26/28. 3 страницы. Язык - английский.
Тип файла: pdf bmw_zf_6hp_sealing_sleeve_seepage.pdf (135.7 Кб, 525 просмотров)
deso_bg (22.02.2019), killshev (26.04.2012)
Старый 24.11.2010, 13:44 #34
  • Заключение эксперта о причине дефекта АКПП ZF 5HP19 в автомобиле BMW. 29 страниц. Формат PDF. Язык - русский.
Рассмотрены вопросы:
1. Какова причина выхода из строя исследуемой АКПП на автомобиле BMW VIN: *********?
2. Является ли причина неисправности АКПП следствием некачественного
ремонта по Заказ – Наряду №******?
3. Могли ли действия лица после ремонта по Заказ – Наряду №******, управлявшего автомобилем привести к таким неисправностям?
4. Может ли потеря масла в АКПП привести к повреждению трансмиссии целиком?
Тип файла: pdf www.bmwpost.ru_BMW_ZF_5HP19_expert.pdf (3.85 Мб, 520 просмотров)
eric (04.11.2012), Hook (22.09.2015), killshev (26.04.2012)
Старый 25.11.2010, 15:24 #35
  • Мануал АКПП ZF 6HP19 / 6HP21. 31 страница. Техническая информация + каталог деталей. Язык - английский.
Содержание:
6HP19 / 6HP21 Lubricants________________________________________ 2
6HP19 / 6HP21 Technical Literature________________________________2
6HP19 / 6HP21 General Transmission Oil Filling Procedure______________3-5
How To Use This Catalog_________________________________________6
Type Plate Information_______________________________________ ____7
6HP19 1071 010 XXX / 6HP21 1071 030 XXX
Spare Parts
Gearbox Housing Group__________________________________________8
Torque Converter Group_________________________________________9
Oil Supply Group_____________________________________________ __10
Front Planetary Group___________________________________________11
Rear Planetary Group____________________________________________1 2
Coupling A Group_____________________________________________ __13
Coupling B Group_____________________________________________ _ 14
Coupling C Group_____________________________________________ _ 15
Coupling D Group_____________________________________________ _ 16
Coupling E Group_____________________________________________ _ 17
Output Group_____________________________________________ _____18
Filter Group_____________________________________________ _______19
Mechatronic Group_____________________________________________ _20
Gear Shift System E-Shift Group___________________________________21
Gear Shift System M-Shift Group___________________________________22
Parking Lock Group____________________________________________ 23
Selective Shims, Snap Rings & Kits Content
Selective Shims_____________________________________________ __ 24
Selective Snap Rings____________________________________________2 5-26
Kits Content___________________________________________ ________27- 29
Тип файла: pdf www.bmwpost.ru_ZF_6HP_19-21.pdf (935.2 Кб, 529 просмотров)
Тип файла: pdf www.bmwpost.ru_zf6hp19.pdf (193.1 Кб, 396 просмотров)
andrey75r (07.09.2011), deso_bg (22.02.2019), eric (04.11.2012), wadim_2011 (02.08.2011)
Старый 25.11.2010, 15:44 #36
  • Немного информации по коробкам ZF 6HP32 и 6HP32A. 4 страницы. Язык: немецкий / английский.
Тип файла: pdf 6HP_32.pdf (631.3 Кб, 202 просмотров)
Тип файла: pdf 6HP32A.pdf (234.7 Кб, 162 просмотров)
dmss likes this.
eric (04.11.2012)
Старый 25.11.2010, 15:51 #37
  • Мануал по АКПП ZF 6HP32. Содержит номера деталей, ремкомплектов. Формат PDF. 15 страниц.
  • И ещё один вариант. 4 страницы.
Тип файла: pdf www.bmwpost.ru_6HP32.pdf (1.05 Мб, 183 просмотров)
Тип файла: pdf www.bmwpost.ru_zf6hp32.pdf (174.7 Кб, 140 просмотров)
Старый 25.11.2010, 15:57 #38
  • Список всех коробок ZF на все автомобили (в т.ч. и BMW). 332 страницы. Формат PDF.
Тип файла: pdf www.bmwpost.ru_Overview_gearbox_cars.pdf (1.08 Мб, 431 просмотров)
alex3158 (15.12.2014)
Старый 09.02.2011, 17:36 #39
  • Официальный мануал по АКПП ZF 6HP26X / 6HP28X. 42 страницы. Техническая информация + каталог деталей. Язык - английский.
Содержание:
6HP26X / 6HP28X
6HP26X / 6HP28X Lubricants_____________________________________2
6HP26X / 6HP28X Technical Literature______________________________2
6HP26X / 6HP28X General Transmission Oil Filling Procedure___________3-7
6HP26X 1068 020 XXX / 6HP28X 1068 050 XXX
Spare Parts
Filter Group
Filter General__________________________________________2 1
Filter BMW___________________________________________22
Filter Ford____________________________________________23
Mechatronic Group_____________________________________________ _24
Gear Shift System E-Shift Group___________________________________25
M-Shift BMW__________________________________________26
M-Shift BMW__________________________________________27
M-Shift LAND ROVER__________________________________28
M-Shift Ford__________________________________________29
Parking Lock Group_____________________________________________ 30
Selective Shims_____________________________________________ ___31
Selective Snap Rings____________________________________________3 2-33
Selective Steel Plate_____________________________________________ 34
Kits Content___________________________________________ ________35-40
Тип файла: pdf www.bmwpost.ru_6HP26X-28X.pdf (1.18 Мб, 576 просмотров)
eric (04.11.2012)
Старый 09.02.2011, 17:43 #40
  • Мануал по АКПП ZF 6HP26, 6HP26X, 6HP28, 6HP28X. Содержит номера деталей, ремкомплектов. Формат PDF. 6 страниц.
Тип файла: pdf www.bmwpost.ru_zf6hp26-26x-28-28x.pdf (200.2 Кб, 453 просмотров)
545irbis (09.02.2011), eric (04.11.2012), Динара (25.10.2012)
4hp20, 4hp22, 5hp19, 5hp24, 5hp30, 6hp19, 6hp21, 6hp26, 6hp26x, 6hp28x, 6hp32, 8hp45, 8hp70
Мануалы по ремонту и регулировке АКПП GM Tyler Инструкции, Мануалы BMW 7 27.05.2013 00:23
Мануалы, инструкции, руководства на МКПП и АКПП BMW Tyler Инструкции, Мануалы BMW 2 08.02.2011 16:35
Часовой пояс GMT +3, время: 17:51.
