| | #11 | |||
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки |
1. Start the engine (it may work with only ignition on, I have not tried it) and make sure you have all doors and boot closed. If one door is open, it will not work. 2. Press the odometer reset button and keep it pressed until the BC screen changes (at least 10''). 3. When the screen changes, release the button. It will display a menu with numbered options. To scroll to each option you have press once the ODO resete button. 4. Go to option No. 4 UNLOCK and then press the odo reset button for a few seconds. It will enter the menu of this option and it will ask you for the unlock code. 5. The unlock code is the sum of the last 5 digits of your VIN. For example if your VIN is E123456, then the unlock code will be the number 20. 6. Enter the unlock code by pressing the odo reset button so many times required (in our example 20 times), until the number of the unlock code is displayed on the screen. If you accidentaly press the button more times than the required, worry not, just keep pressing it until it starts from 0 again. 7. Once you enter the unlock code, press again the odo rest button for a few seconds, to go to the previous menu. Now, the full unlocked menu should be displayed. 8. Scroll through all the option. Option No. 8 ''Temperature'' displays the outside temp, oil temp and coolant temp. To enter this option just press for a few seconds the odo reset button. In general,when you are inside the hidden menu, by pressing the odo reset button once, you scroll through the options. By pressing it for a few seconds you will either enter the menu displayed or go back to the previous menu, depending on which screen you are at.
__________________ ![]() Чат по кодированию, программированию, дооснащению BMW в Telegram: BMW INPA | BMW ICOM | BMW Scanner | Ключи BMW | BMW CAN filter (cic retrofit adapter) | Отключение BMW EGR / DPF | Ноутбуки для диагностики Сканеры для диагностики BMW Инструкции, мануалы к БМВ бесплатно BMW & MINI: TIS, ЕТК, ЕТМ, KSD, WDS, DIS, EBA и другие полезные программы | |||
| Сказал Спасибо Tyler за это сообщение: | Valve (08.10.2015) |
| | #12 |
| | #13 |
1. Parts list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 2. Preparatory work . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 3. Installing the charge air cooler . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 4. Exchanging the engine control unit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 5. Attaching the badge . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 6. Concluding work and coding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
| Эти 2 пользователя(ей) сказали Спасибо Tyler за сообщение: | krokodil gena (12.01.2020), zalimhan74 (23.04.2015) |
| | #14 |
Overview 10 Cockpit 14 iDrive 21 Voice control system 24 Integrated Owner’s Handbook in the vehicle Controls 28 Opening and closing 42 Adjusting 52 Carrying children in safety 57 Driving 67 Displays 83 Lights 90 Security 98 Driving stability control systems 103 Driving comfort 116 Climate 122 Interior equipment 126 Storage compartments Driving hints 132 Driving precautions 135 Loads 137 Towing a trailer 142 Saving fuel Navigation 148 Navigation system Entertainment 168 Sound 170 Radio 176 CD/multimedia Communication 200 Telephone 210 Office 219 Contacts 222 ConnectedDrive 231 Extended BMW Online services Mobility 234 Refuelling 236 Fuel 238 Wheels and tyres 246 Engine compartment 248 Engine oil 251 Coolant 252 Maintenance 255 Replacing parts 265 Help in the event of a breakdown 271 General care Reference 278 Technical data 286 Short commands of the voice control system 294 From A to Z
| Эти 2 пользователя(ей) сказали Спасибо Tyler за сообщение: | bubiuxas (09.09.2014), krokodil gena (12.01.2020) |
| | #15 |
| Сказал Спасибо Tyler за это сообщение: | Владимир Иванов (25.01.2016) |
| | #19 |
| Завсегдатай Регистрация: 29.03.2014
Поблагодарили 82 раз(а) в 76 сообщениях
Откуда: Москва Авто: E60 530D, E32 735iA | Что значит схему? Порядок разборки/сборки? Тебе проще поставить рейнголд и посмотреть самому. Там все расписано пошагово. Вот основная страница в pdf Последний раз редактировалось ViC530; 29.09.2014 в 18:35. |
| Ликвидация новых запчастей по закупке | АндрейСергеевич | Продажа запчастей BMW | 2 | 02.07.2024 16:26 |
| Все опции БМВ на русском языке | Tyler | Выбираем БМВ | 21 | 19.06.2014 12:09 |
| Модельный ряд BMW пополнил автомобиль BMW 740d | Tyler | Новости BMW | 3 | 30.07.2009 19:24 |
| BMW 5 серии Gran Turismo на Женевском автосалоне 2009 | Tyler | Новости BMW | 0 | 26.02.2009 18:00 |
