Вернуться   Форум владельцев и любителей БМВ > BMWorld > Инструкции, Мануалы BMW > 1-er
BMW F20
Like Tree6Likes
Старый 07.01.2013, 15:51 #11
  • Скрытое сервисное меню BMW F20.
1. Start the engine (it may work with only ignition on, I have not tried it) and make sure you have all doors and boot closed. If one door is open, it will not work.
2. Press the odometer reset button and keep it pressed until the BC screen changes (at least 10'').
3. When the screen changes, release the button. It will display a menu with numbered options. To scroll to each option you have press once the ODO resete button.
4. Go to option No. 4 UNLOCK and then press the odo reset button for a few seconds. It will enter the menu of this option and it will ask you for the unlock code.
5. The unlock code is the sum of the last 5 digits of your VIN. For example if your VIN is E123456, then the unlock code will be the number 20.
6. Enter the unlock code by pressing the odo reset button so many times required (in our example 20 times), until the number of the unlock code is displayed on the screen. If you accidentaly press the button more times than the required, worry not, just keep pressing it until it starts from 0 again.
7. Once you enter the unlock code, press again the odo rest button for a few seconds, to go to the previous menu. Now, the full unlocked menu should be displayed.
8. Scroll through all the option. Option No. 8 ''Temperature'' displays the outside temp, oil temp and coolant temp. To enter this option just press for a few seconds the odo reset button.
In general,when you are inside the hidden menu, by pressing the odo reset button once, you scroll through the options. By pressing it for a few seconds you will either enter the menu displayed or go back to the previous menu, depending on which screen you are at.
Valve (08.10.2015)
Старый 17.01.2013, 17:35 #12
  • Фотоотчеты по ремонту, дооснащению BMW F20: [Только для зарегистрированных...].
Старый 08.04.2013, 00:56 #13
  • Инструкция по установке BMW M Performance Power Kit на F20, F21, F22, F23, выпущенных после 07/11. 8 страниц. Язык - английский.
Содержание:
1. Parts list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
2. Preparatory work . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
3. Installing the charge air cooler . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
4. Exchanging the engine control unit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
5. Attaching the badge . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
6. Concluding work and coding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Тип файла: pdf www.bmwpost.ru-EDoc1717983792.pdf (127.6 Кб, 403 просмотров)
Эти 2 пользователя(ей) сказали Спасибо Tyler за сообщение:
krokodil gena (12.01.2020), zalimhan74 (23.04.2015)
Старый 21.04.2013, 18:09 #14
  • Руководство (инструкция) по эксплуатации BMW F20. 304 страницы. Язык - английский. В руководстве рассмотрены модели BMW F20 116i, 118i, 125i, 116d, 116ed, 118d, 120d, 125d.
Содержание:
Overview
10 Cockpit
14 iDrive
21 Voice control system
24 Integrated Owner’s Handbook in the vehicle
Controls
28 Opening and closing
42 Adjusting
52 Carrying children in safety
57 Driving
67 Displays
83 Lights
90 Security
98 Driving stability control systems
103 Driving comfort
116 Climate
122 Interior equipment
126 Storage compartments
Driving hints
132 Driving precautions
135 Loads
137 Towing a trailer
142 Saving fuel
Navigation
148 Navigation system
Entertainment
168 Sound
170 Radio
176 CD/multimedia
Communication
200 Telephone
210 Office
219 Contacts
222 ConnectedDrive
231 Extended BMW Online services
Mobility
234 Refuelling
236 Fuel
238 Wheels and tyres
246 Engine compartment
248 Engine oil
251 Coolant
252 Maintenance
255 Replacing parts
265 Help in the event of a breakdown
271 General care
Reference
278 Technical data
286 Short commands of the voice control system
294 From A to Z
Тип файла: pdf www.bmwpost.ru-1-Series-(F20-E82-E88)-BMW-Handbook-1-Series-0312.pdf (11.38 Мб, 150 просмотров)
bubiuxas (09.09.2014), krokodil gena (12.01.2020)
Старый 21.04.2013, 18:17 #15
  • Схема предохранителей BMW F20.
Изображения
Тип файла: jpg www.bmwpost.ru-f20-fuses.jpg (99.3 Кб, 203 просмотров)
Тип файла: jpg www.bmwpost.ru-f20-fuses2.jpg (116.2 Кб, 196 просмотров)
Старый 29.09.2014, 08:53 #16
Авто: BMW 1 f 21
У кого нибудь есть схема замены цепи на бмв 1 ф 20 двигатель N13B16A
Dimas777 вне форума   Ответить с цитированием
Старый 29.09.2014, 17:55 #17
Авто: BMW 1 f 21
Скиньте пожалуйста схему как поменять цепь.
Старый 29.09.2014, 17:58 #18
Авто: BMW 1 f 21
На бмв 1 ф 20 N13B16A
Старый 29.09.2014, 18:04 #19
Аватар для ViC530
Поблагодарили 82 раз(а) в 76 сообщениях
Авто: E60 530D, E32 735iA
Сообщение от Dimas777 Посмотреть сообщение
Что значит схему? Порядок разборки/сборки?
Тебе проще поставить рейнголд и посмотреть самому. Там все расписано пошагово.
Вот основная страница в pdf
Последний раз редактировалось ViC530; 29.09.2014 в 18:35.
ViC530 вне форума   Ответить с цитированием
Часовой пояс GMT +3, время: 23:36.
