2006 BMW E90 не запускается
Старый 04.02.2014, 19:27 #11
Аватар для hackbest
Авто: bmw e39 530i
ok I'll remove the ecu to read car
Do you know where this car is located in
hackbest вне форума   Ответить с цитированием
Старый 04.02.2014, 23:21 #12
Аватар для hackbest
Авто: bmw e39 530i
and have removed this isn the eeprom 95640
Well here reading the eeprom of ecu
Please help I'm desperate
Тип файла: rar eeprom 95640 ecu e90.rar (2.6 Кб, 15 просмотров)
Старый 05.02.2014, 17:00 #13
you are scary man.
With dumps that do, then read half, then with the Board ISN ... who do not understand its rules, like machine "went around the circle." ISN ECU coincides with your previous dump, restore them in the second dump, try. But after such bullying difficult to restore the chronology of events, take and read the error diagnostics, and her sync variable part, if the edited version of the dump will not work.
Тип файла: rar bmw_corr.rar (1,018 байт, 15 просмотров)
visht вне форума   Ответить с цитированием
Старый 05.02.2014, 22:22 #14
Аватар для hackbest
Авто: bmw e39 530i
do not quite understand that I do burn this file you send me
Старый 06.02.2014, 03:18 #15
Аватар для hackbest
Авто: bmw e39 530i
visht here have a good read like a cas mia wing can be modified for my car
Тип файла: zip 61.35-6943791_CAS2_2006_Fullmy.zip (205.2 Кб, 28 просмотров)
Старый 06.02.2014, 14:39 #16
Simply replace your eeprom if you trust your programmer.
Comparing Flash I would not trust.
Старый 06.02.2014, 15:10 #17
Аватар для hackbest
Авто: bmw e39 530i
Just burn eeprom not need to edit anything
Старый 06.02.2014, 19:04 #18
To communicate with the ECU need ISN and Rolling code (synchronized with diagnosis).
For the correctness of the dump Vin mileage and encoding.
To work them keys acc data.
That this should be replaced, as far as I understand you menyaetet iron, then the rest is all correspondence.
Последний раз редактировалось visht; 06.02.2014 в 19:18.
« X3 ms45+ews | ews 3 »
Часовой пояс GMT +3, время: 09:26.
