| BMW EWS, CAS Обсуждаем работу со штатными иммобилайзерами BMW (EWS 1,2,3,3+4; CAS 1,2,3,3+,4). Синхронизация, корректировка пробега, работа с ключами и т.п. |
| | #1 |
Поблагодарили 10,622 раз(а) в 1,958 сообщениях
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки |
BMW E/F SCANNER Купить можно: . Supported model list: • 1-series (E81, E82, E87, E88), 2003+ • 3-series (E90, E91, E92, E93), 2004+ • 5-series (E60), 2002-2010 • 5-series (F10), 2010+ • 5-series “Gran Turismo” (F07), 2009+ • 7-series (E65, E66), 2000-2008 • 7-series (F01, F02), 2007+ • BMW X5 (E70), 2006+ • BMW X6 (E71), 2007+ • Mini Cooper (R56, R57), 2005+ • Rolls-Royce, 2003+ List of supported ECU: • Drive – 6 categories / 30 types; CAS, DME, EGS, EKPM, GWS, VTG • Chassis – 12 categories / 15 types; ASR, CIM, DSC, EDC, EDCSHL, EDCSHR, EDCSVL, EDCSVR, EHC, EMF, RDC, VDM • Body – 65 categories / 121 types; AHM, AMP, BFH, BFS, BZM, CCC, CDC, CHAMP, CIC, CID, DWA, ECL, FAH, FAS, FLA, FOMO, FRM, FZD, HKL, HUD, IHKA, JBBF, KBM, KGM, KOMBI, LMA, MASK, MMC, MMI, MPM, PDC, PGS, RAD, RFK, RLS, RSE, SASL, SASR, SBSL, SBSR, SD, SECUR, SFZ, SGM, SHD, SHZH, SIM, SSBF,SSFA, SSH, STVL, STVR, SZL, SZM, TEBF, TEFA, TEL, TMB, TMBH, TMF, TMFH, VID, WIM, ZBE, ZGM System capabilities: DTC reading with clear text explanation, car setting adjustment, maintenance interval adjustment, key programming or blocking, remote control synchronization and much much more! 1.166 types of ECU supported 2.Diagnosis and interpretation of error codes 3.Reading and adjustment of run hours and maintenance intervals for: Oil, Filters, Brake pads, Spark plugs, Liquids, Inspections and services as well as СО, СН inspections etc. 4.Adjustment of mileage and maintenance intervals 5.Change/Adjust FA code (currently in test mode) 6.CPU CODING 7.Read/Write RAM/FLASH/EEPROM * 8.Read/Write ISN (marriage CAS and DME/DDE) * 9.ELV Reset (steering wheel lock) 10.Key read/write via OBD2 in CAS2, CAS3, CAS3+ ,CAS4* 11.Key prog module for E/F-series 12.Learning key or transponder directly in the ignition lock! 13.Lost keys blocking/unblocking 14.Mileage correction module for E/F-series 15.Change AIF (indexes of programming)* 16.Reading the last saved mileage from ECU VIN change * 17.New battery registration NOTE: Instrument cluster and CAS1-CAS4 must be adjusted MANUALLY software system which allows to read,decode and edit ISN password (It is sync password betweenECU and immobilizer ) Correct checksum also calculated automatically Tech tip: Procedure of used ECU installation in car with automatic transmission: Install used DME/DDE Switch ignition ON. Connect BMW explorer,and run Quick test. Go to EGS ,press Unlock EWS Got to DME/DDE and read ISN Switch ignition OFF,connect to CAS,write down old ISN,write ISN previously read from DME/DDE and save it. Switch ignition ON Go to DME/DDE and make synchronization procedure. |
| Ликвидация новых запчастей по закупке | АндрейСергеевич | Продажа запчастей BMW | 2 | 02.07.2024 16:26 |
| Все опции БМВ на русском языке | Tyler | Выбираем БМВ | 21 | 19.06.2014 12:09 |
| Модельный ряд BMW пополнил автомобиль BMW 740d | Tyler | Новости BMW | 3 | 30.07.2009 19:24 |
| BMW 5 серии Gran Turismo на Женевском автосалоне 2009 | Tyler | Новости BMW | 0 | 26.02.2009 18:00 |
