inpa Error ifh-0010 DME 413 hello I have Cable from **** same this i can read the Air Big but no Read the DME ECU Give me Error IFH-0010 any one can help me? |
Jrak, ..тут смотри [Ссылки могут видеть только зарегистрированные пользователи. Зарегистрироваться...] |
Thank you I'm read and change the Com 8 bit same Error :confused: |
Вложений: 2 this images for cable any one can edit this one for read Dme ECU |
You can't read the dme 413 with obd adapter. You need an ADS one. |
ADS data transmission protocole means that the car's ecu needs 2 lines-k line for data exchange and L-line for the requiry questions from the diagnostic software and ecu installed on the cars. All cars below 1996 requires an ads adapter for diagnostics. From 1996 on E39 and on E38 from 1994 introduced an obd data transmission protocole thats needs only K-line for data exchange between diagnostic software and ecu installed on the car. By the way from 1994 BMW started to install updated ecus on E34 and E36 thats requires only K-line for diagnostic. Update has been affected for the ABS and Air bag control units. That is the reason why you was able to read Air bag control unit. The reason of noabillity to read the Air bag ecu with another usb obd adapter i don't know, probably the wrong presettings or it's even not an obd adapter but VAG K-line adapter for example. So briefly to be able for you to read an dme 413 you need: 1. ADS adapter. Check the forum and ***** for example to know how it looks. 2. If your car is not equipped with EWS2 antitheft system then even with ads adapter and INPA software you will not be able to diagnose it. You will need DIS software preinstalled on your computer. P.S. Надеюсь что админ простит меня за инородный язык на форуме. |
| Часовой пояс GMT +3, время: 20:47. |
