Update: поковырялся еще, обнаружил что такая же ошибка вылазит в INPA и NCS если вообще не подключать интерфейс. |
Копать в сторону режимов работы шнурка |
Reason 1: In the Ediabas.ini file, the interface is set to STD:OBD. However, you have connected an ADS connector. Solution 1: Modify the interface setting. Reason 2: The data transmission failed when sending (e.g. short circuit in the line). Solution 2: Get rid of the short circuit, for example. Reason 3: Connector not connected or no power supplied. Solution 3: Check whether the connector is connected and is supplied with power. Reason 4: The device manager has been used to disable the FIFO buffer for COM1. Solution 4: In the device manager (Windows XP: Enter “Start” à “Control Panel” à “System” à “Hardware” à “Device Manager” à Ports (COM & LPT)), and then select COM1 from the ports. Then under the “Port Settings” tab, select “Advanced”. There must be a check-mark by “Use FIFO buffers” and “8” must be selected for the receive buffer and transmit puffer. IFH-0009: ECU isn’t connected or doesn’t respond Reason 1: In the Ediabas.ini file, the interface is set to STD:ADS. However, you have connected an OBD connector. Solution 1: Modify the interface setting. Reason 2: The ignition is switched off. Solution 2: Switch the ignition on. Reason 3: The device manager has been used to disable the FIFO buffer for COM1. Solution 3: In the device manager (Windows XP: Enter “Start” à “Control Panel” à “System” à “Hardware” à “Device Manager” à Ports (COM & LPT)), and select COM1 from the ports and under the “Port Settings” tab, select “Advanced”. There must be a check-mark by “Use FIFO buffers” and the highest possible setting must be selected for the receive buffer. |
Спасибо, конечно, за расшифровку ошибок, только я их и сам нашел. Пытался сменить режим шнурка на DCAN с помощью dcan_tools, и через виндовое приложение, и через ДОСовское. Ругается на echo timeout. Может шнурок капут? |
Устройство определяется в системе? как определяется? Попробуй дрова смени |
Спасибо всем отозвавшимся, все вылечилось сменой шнурка на модель подороже. |
Лучше на нём повеситься всем "диагностам", не знающим слова "адаптер" :piska::biggrin1: |
Кто может подсказать,кодил сегодня себе некоторые вещи,заметил,что NCS неверно определяет VIN,точнее последнюю его цифру,вместо 0 пишет 3,кодирнулось все нормально,это глюк какой то или что? |
| Часовой пояс GMT +3, время: 19:28. |
