-   Форсаж (https://bmwpost.ru/forum/forsazh-21/)
-   -   BMW F10 M5 - выхлоп Eisenmann (https://bmwpost.ru/forum/forsazh-21/bmw-f10-m5-vyhlop-eisenmann-21653/)
Tyler 17.10.2012 00:54
Просто для звука :smile:
You’ll need to lift the rear of the car, either by putting the car on a lift or placing the car securely on jackstands.
This shot shows the section of piping where a cut will be made to allow the Eisenmann rear mufflers to be installed.
Line up the Eisenmann rear muffler directly below the original BMW system. The key is to align the Eisenmann hangers so that they are immediately below the BMW exhaust hangers.
The Eisenmann exhaust piping contains an expanded section that is designed to slip over the original BMW piping. Use a straight edge to align the beginning of the expanded section with the original piping, and place a mark on the original piping. The goal here is to ensure there is a sufficient length of original BMW piping to slip inside the Eisenmann piping. Remember to measure twice and check your measurements as this step is important!
At this point you can use some masking tape to mark a complete line.
Use a pipe cutting tool to cut the connecting pipe
The mufflers are removed by unbolting the exhaust hangers. We will have some more detailed photos of the hanger locations early next week.
The system we installed on this car used Eisenmann’s Oval exhaust tips, and a rear diffuser is provided to accommodate the larger tips. Prior to installing the Eisenmann system the original BMW diffuser must be removed. This is accomplished by first removing the black plastic rivets by using either a panel puller or a flat head screwdriver.
Once the plastic rivets have been removed, you can pull the diffuser off of the rear bumper, one clip at a time. Move along the diffuser, and it will release from the rear bumper.
The wiring in the photo above should be unclipped from it’s plastic retainer, and slid directly behind the diffuser. This moves the wiring away from the exhaust tips.
At this point you can transfer the exhaust hangers from your original BMW muffler to the Eisenmann muffler. Raise the Eisenmann muffler slide the provided clamp over the OE BMW piping, and slide the Eisenmann piping over the BMW piping at this point. Raise the hangers to their original positions, and screw the original nuts back into place one by one. Tighten the clamp, but leave all of the nuts somewhat loose at this point, to allow for adjustment of the muffler tips.
Installation of the modified diffuser is reverse of removal. The modified diffuser is a trimmed OEM BMW piece, so it will fit exactly like factory. Simply snap the clips into the bumper one at a time, and re-install the plastic rivets.
AW vs. Gloss black diffuser-
The tip position can be adjusted by sliding the Eisenmann muffler forward and back on the original BMW piping, and also twisting it axially on the same piping. This will adjust the distance that the tips are exposed as well as the level and angle of the tips.
Once the tips are evenly positioned and angled relative to the rear diffuser, you can tighten the clamps and exhaust hanger nuts.
You’re done! Enjoy the sound of your new exhaust!
Please keep in mind that this installation procedure applies to the oval tip slip on system only. The round tip exhaust systems do not require a different diffuser, and the full systems are completely bolt on and do not require cutting of your original exhaust.
mihhail 17.10.2012 09:48
:thumbup::thumbup::thumbup:
Часовой пояс GMT +3, время: 12:39.
