Вложений: 1
Technical Information Torque, Gear Ratio & Weight______________________________________2 Oil Capacity__________________________________________ _________2 6HP26 / 6HP28 Lubricants________________________________________ 2 6HP26 / 6HP28 Technical Literature________________________________2 6HP26 / 6HP28 General Transmission Oil Filling Procedure______________3-7 How To Use This Catalog_________________________________________8 Type Plate Information_______________________________________ ____9 Spare Parts Gearbox Housing Group__________________________________________10 Torque Converter Group_________________________________________11 Oil Supply Group_____________________________________________ __12 Front Planetary Group___________________________________________13 Rear Planetary Group____________________________________________1 4 Coupling A Group_____________________________________________ __15 Coupling B Group_____________________________________________ __16 Coupling C Group_____________________________________________ __17 Coupling D Group_____________________________________________ __18 Coupling E Group_____________________________________________ __19 Output Group_____________________________________________ _____20 Filter Group_____________________________________________ _______21 Mechatronic Group_____________________________________________ _22 Gear Shift System E-Shift Group___________________________________23 Gear Shift System M-Shift Group___________________________________24 Parking Lock Group_____________________________________________ 25 Selective Shims, Snap Rings, Steel Plate & Kits Content Selective Shims_____________________________________________ ___26 Selective Snap Rings____________________________________________2 7-28 Selective Steel Plate_____________________________________________ 29 Kits Content___________________________________________ ________30-35 |
Вложений: 2
The 6HP gearbox-family Hints for the repairshop: General hints gearbox change change of a mechatronic change of a oilpan and filter changing or adding oil
Вложений: 1
Вложений: 1
1. Какова причина выхода из строя исследуемой АКПП на автомобиле BMW VIN: *********? 2. Является ли причина неисправности АКПП следствием некачественного ремонта по Заказ – Наряду №******? 3. Могли ли действия лица после ремонта по Заказ – Наряду №******, управлявшего автомобилем привести к таким неисправностям? 4. Может ли потеря масла в АКПП привести к повреждению трансмиссии целиком? |
Вложений: 2
Technical Information Torque, Gear Ratio & Weight______________________________________2 Oil Capacity__________________________________________ _________2 6HP19 / 6HP21 Lubricants________________________________________ 2 6HP19 / 6HP21 Technical Literature________________________________2 6HP19 / 6HP21 General Transmission Oil Filling Procedure______________3-5 How To Use This Catalog_________________________________________6 Type Plate Information_______________________________________ ____7 6HP19 1071 010 XXX / 6HP21 1071 030 XXX Spare Parts Gearbox Housing Group__________________________________________8 Torque Converter Group_________________________________________9 Oil Supply Group_____________________________________________ __10 Front Planetary Group___________________________________________11 Rear Planetary Group____________________________________________1 2 Coupling A Group_____________________________________________ __13 Coupling B Group_____________________________________________ _ 14 Coupling C Group_____________________________________________ _ 15 Coupling D Group_____________________________________________ _ 16 Coupling E Group_____________________________________________ _ 17 Output Group_____________________________________________ _____18 Filter Group_____________________________________________ _______19 Mechatronic Group_____________________________________________ _20 Gear Shift System E-Shift Group___________________________________21 Gear Shift System M-Shift Group___________________________________22 Parking Lock Group____________________________________________ 23 Selective Shims, Snap Rings & Kits Content Selective Shims_____________________________________________ __ 24 Selective Snap Rings____________________________________________2 5-26 Kits Content___________________________________________ ________27- 29 |
Вложений: 2
Вложений: 2
Вложений: 1
Вложений: 1
6HP26X / 6HP28X Technical Information Torque, Gear Ratio & Weight______________________________________2 Oil Capacity__________________________________________ _________2 6HP26X / 6HP28X Lubricants_____________________________________2 6HP26X / 6HP28X Technical Literature______________________________2 6HP26X / 6HP28X General Transmission Oil Filling Procedure___________3-7 How To Use This Catalog_________________________________________8 Type Plate Information_______________________________________ ____9 6HP26X 1068 020 XXX / 6HP28X 1068 050 XXX Spare Parts Gearbox Housing Group__________________________________________10 Torque Converter Group_________________________________________11 Oil Supply Group_____________________________________________ __12 Front Planetary Group___________________________________________13 Rear Planetary Group____________________________________________1 4 Coupling A Group_____________________________________________ __15 Coupling B Group_____________________________________________ __16 Coupling C Group_____________________________________________ __17 Coupling D Group_____________________________________________ __18 Coupling E Group_____________________________________________ __19 Output Group_____________________________________________ _____20 Filter Group Filter General__________________________________________2 1 Filter BMW___________________________________________22 Filter Ford____________________________________________23 Mechatronic Group_____________________________________________ _24 Gear Shift System E-Shift Group___________________________________25 Gear Shift System M-Shift Group M-Shift BMW__________________________________________26 M-Shift BMW__________________________________________27 M-Shift LAND ROVER__________________________________28 M-Shift Ford__________________________________________29 Parking Lock Group_____________________________________________ 30 Selective Shims, Snap Rings, Steel Plate & Kits Content Selective Shims_____________________________________________ ___31 Selective Snap Rings____________________________________________3 2-33 Selective Steel Plate_____________________________________________ 34 Kits Content___________________________________________ ________35-40 |
Вложений: 1
| Часовой пояс GMT +3, время: 08:10. |
