| Навигация Всё о GPS навигации. Карты, прошивки...Обмен опытом. |
| | #11 | |
| Абориген Регистрация: 28.10.2009
Сказал спасибо: 30
Поблагодарили 335 раз(а) в 174 сообщениях
перевод!Я вчера видел в мк-2 русское меню! ![]() Вот текст для перевода кто хочет юзайте!!! МК-2С GB English 2 2 WARNING! Use this system only when traffic and environmental conditions permit. Observe traffic rules and situations. Safe operation of the vehicle is the driver's responsibility. Always wear your seat belt. Accept Monitor has switched off due to high temperature. MENU On-board computer Trip Computer GPS-navigation Telephone Emergency BMW ASSIST BMW ASSIST BMW ASSIST STATUS BMW Emergency Service BMW EMERGENCY SERVICE BMW information BMW INFORMATION A new message is being called up. Deleting message. Sending reply. Your request could not be transmitted. Your reply could not be transmitted. Information plus INFORMATION PLUS Service selection Service selection Traffic info plus Deactivate traffic information Telefonnr.: Start new enquiry Activate Emergency call in s. Traffic information TRAFFIC INFORMATION Call set-up to operator faulty. Data could not be transmitted to the vehicle. Do not switch off the system while initialisation is in progress (ignition on)! The process will take a few minutes. SOS / breakdown T-info T-info plus Information plus Status Data Retry Attempting connection Transmitting data If no answer - press RETRY VIN: Emergency call activated Position transmitted successfully Network error, connecton not possible Your car' s position could not be transmitted Police emergency call activated Breakdown service activated Information plus activated. BMW Service Center call Service automatically terminated. Data communication faulty Service terminated No response to dialogue Initialising BMW Assist... Requested Data successfully transferred. Phase 1 of 4 Phase 2 of 4 Phase 3 of 4 Phase 4 of 4 An error has occurred. Initialisation not possible. Your enquiry has been rejected. Would you like to call an operator? Telematic services deactivated. Your message could not be processed by the system. Stop Enquiry Answer Aux. heat/vent Television DSP Code Monitor off Screen Off SMS SMS messages CURRENT DESTINATION >> << Dial number LIMIT switch on switch off Speed Note: To activate, turn ignition key to "0". TIMER stop start Interim time return CONSUMPTION 1 Recalculate? yes no CONSUMPTION CONSUMPTION 2 AVERAGE SPEED OUTSIDE TEMPERATURE RANGE DISTANCE ARRIVAL TIME DEMO Memo 1 Memo 2 Memo 3 Concert Hall Jazz Club Cathedral 80 200 500 1K 2K 5K 12K Room Echo Memo Demo ROOM SIZE ECHO 200HZ 5KHZ TIMER PRESET off on set SERVICE DIRECT MODE Aux. heating Aux. ventilation CODE change deactivate Emergency deactivation, wait: SET Language Distance Units Trip Distance Consumpt. Temp. Clock Memo Date Audio+OBC OBC displ. Colour set Day/Night DATE TIME set REMOTE CONTROL Limit Range Out. temp. Rear Serial number Software version Timer Consump. Average Consumption Consump 1 Consump 2 Speed Average Speed Timer 1 Timer 2 memorise SERVICE MODE On-board monitor NAVIGATION / GRAPHIC ELEMENT Video module GPS Sensor check SENSOR CHECK VIN VIN Wheel sensor: GPS satellites: GPS status: Gyro: Direct. of travel: Forward Backward GPS fault Reception interf. No almanac Satellite search Satellite contact Position known Version Key function Brightness ON-BOARD MONITOR VERSION SW level: HW level: DIAG index: BUS index: Encoding Index: Supplier: ON-BOARD MONITOR KEY FUNCT. Key: OBM increm. sensor: Radio increment sensor: ON-BOARD MONITOR BRIGHTNESS CTRL. Slider NAVI/GRAPHIC ELEMENT VIDEO MODULE VERSION GPS VERSION Receiver SW vers.: Receiver SW date: GPS version GPS status GPS tracking info GPS STATUS Latitude: Longitude: Altitude: Date/time (UTC): G-speed/heading: Rec-Stat/Pos-Src: PDOP/HDOP/VDOP: GPS TRACKING INFO Ch PRN S/N 1 2 3 4 5 6 7 8 Visible satellites: Almanac: Heating currently too hot Cool down Junction: I < I > Search non sensitive II < II > Search sensitive m < m > Manual station choice SCAN Station sample a Automatic search Fader front rear Balance left right Bass min. max. Treble F Q GAL Seek level TP-Volume AF Area TAPE Set << >> Fast forward / reverse < > Music search CD Track RANDOM Random generator Track sample City: Road: Destination input map Dest. guide Destination guide Dest. input length in last exit in Diversion T-info RDS-TMC No RDS-TMC function available No TMC station located No messages TMC messages TMC MESSAGES Map Accidents Stop-and-go Parking Slippery road Danger Heavy winds Delay Slow traffic Stationary traffic Closed road Roadworks Delete delete Index enter space A B C D E F G H I J K L M N O P Q R S T U V W X Y Z . ' - , 1 2 3 4 5 6 7 8 9 0 Destination memory Vehicle position On main roads On minor roads Fastest route Shortest route Country: INDEX VOLUME NAVIGATION ROUTE SELECTION DESTINATION MEMORY Retrieve address Enter address Enter current car position Delete address Delete address? Delete all entries? Last destinations LAST DESTINATIONS Return to starting point Instruction Route map New route Information INFORMATION Scale SCALE Cursor Save destination Map positioning MAP POSITIONING °C °F km miles l/100km mpg km/l Arrival min s ENTER ADDRESS Crossing the junction Route selection Info on destination INFO ON DESTINATION Info on current location INFO ON CURRENT LOCATION dd.mm mm/dd 24 h 12 h Arrival time Name: New route for Volume navigation Address cannot be memorised Address not on CD Pointing North Direct. of travel Emergency EMERGENCY Heading: EMERGENCY TELEPHONE Your current position is: North South West East 911 Assist Please dial 911 or Roadside Assist Functions Directory Dial Info TOP-8 MEMORY << >> Last numbers Strength: Call fees current: total: Call time: Consump 1 Consump 2 Average speed Vehicle position outside map limits Correct dest. guidance not possible. Loading of software required. Please insert a suitable CD-ROM No CD in navigation computer. CD-ROM in navigation computer. Software will be loaded Please insert CD! Incorrect CD in navigation computer. Please insert appropriate CD Wrong software in navigation computer Please insert software-CD RECALL ADDRESS DELETE ADDRESS RETRIEVE DESTINATION DELETE DESTINATION INPUT DESTINATION VEHICLE POSITION Street map Delete destination Delete destination? Please wait a moment ... Demo Navigation demo active Change CD before driving and turn ignition key to "0" for at least 30 s. ROUTE LIST Route list Services Emergency Breakdown Profile Vehicle Colour RED ORANGE YELLOW GREEN BLUE BLACK WHITE SILVER BROWN OTHER UNKNOWN Automatic Standard Telematics settings Telematics settings VIN Vehicle type Reg. number Colour SMS-C number D1 Nummer Aut. Em-call initialise Sign-off update initialising completed : Off Road Menu Road Navigation Off Road Navigation Alt Radius GMT HDG BRG ETE STATUS Guidance Forward Reverse Backtrack Route : Routes CURR. Pos Dest. input GOTO Dest. GoTo Timing Map Display Guidance Display Help ° ' " Route list End Guidance Current Route Return >New route< Guidance Full Route Select First Waypoint Review Route Copy Route Paste Route Delete Route Edit Waypoint Insert Waypoint before Insert Waypoint after Copy Waypoint Current Position Paste Notepad Delete Waypoint INSERT ROUTE No new route Skip to next waypoint Insert ... WARNING ! PLEASE DRIVE SAFELY, WEAR YOUR SEATBELT. THE NAVIGATION SYSTEM IS NO SUBSTITUTE FOR THE OBSERVANCE OF TRAFFIC LAWS AND CONSTANT ATTENTION TO ACTUAL TRAFFIC SITUATIONS. FOR YOUR SAFETY DO NOT ENTER DATA INTO THE NAVIGATION SYSTEM WHILE DRIVING. PLEASE PRESS THE ENTER BUTTON TO ACCEPT. Data Display Map Display Start Stop Reset Time to Time from TIMING TO TIMING FROM RESET STOPWATCH Saturday Sunday Monday Tuesday Wednesday Thursday Friday °C °F km/h mph km mls l/100km mpg mpg km/l h min s miles CONCERT HALL JAZZ CLUB CATHEDRAL MEMO 1 MEMO 2 MEMO 3 BMW DEALER/SERVICE PETROL STATION CAR RENTAL CAR PARK CAR PARK + PUBLIC TRANSPORT REST AREA AUTOMOBILE CLUB TOURIST ATTRACTION HOTEL RESTAURANT BANK COMMUNITY CENTRE LIBRARY LAW COURTS FIRE STATION MILITARY BASE CONSULATE/EMBASSY CASH DISPENSER TOURIST INFORMATION MUSEUM THEATRE / CIVIC CENTRE CIVIC CENTRE SPORTS CENTRE CHURCH MONUMENT AMUSEMENT PARK PARK / RECREATION / FITNESS EXHIBITION/CONVENTION CENTRE HOSPITAL POLICE TOWN HALL POST OFFICE MEDICAL ASSISTANCE CHEMIST SHOPPING CENTRE CITY CENTRE THEATRE / CIVIC CENTRE RAILWAY STATION AIRPORT FERRY BUS STATION MARINA COLLEGE/UNIVERSITY ENTERTAINMENT GOLF COURSE INDUSTRIALESTATE m SCAN II I T TP ST FMA FM1 FM2 MW LW SW AMA AM RDS TAPE ERROR TAPE CLEAN 1 2 A B >> <<R SCAN RND <<>> >> <<R > <R <<>> TELEPHONE PIN-CODE TOP-8 DIRECTORY DIAL INFO Info Info Info NO STATION TRAFFIC 1 TRAFFIC 2 NO STATION WB CH 1 WB CH 2 WB CH 3 WB CH 4 WB CH 5 | |
| Русификация CCC | Владимир Белгород | Навигация | 857 | 12.09.2025 06:55 |
| Диагностика, дооснащение, кодирование, программирование, русификация BMW | Tyler | Ремонт и эксплуатация BMW | 0 | 06.07.2012 18:59 |
| Русификация Toyota и Lexus пятого поколения | Юра 535 | Барахолка | 1 | 20.02.2012 11:55 |
| Русификация E39 | BAV1406 | Навигация | 18 | 03.10.2011 15:19 |
