| Общий форум Обсуждение автомобилей, новых технологий, тест-драйвы, любые разговоры и флуд на тему BMW. |
| | #1 |
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки |
BMW M4 DTM фото Технические характеристики BMW M4 DTM Chassis: carbon-fibre monocoque with integrated tank and steel roll cage; carbon-fibre crash elements on sides; carbon fibre crash elements on front and rear Length/width/height: 4,775 mm/1,950 mm/approx. 1,200 mm Tank capacity: 120 litres Engine: 90° V8 aspirated engine, four valves per cylinder, 2 x 28.0 mm air restrictors (in accordance with regulations) Capacity: 4,000 ccm Output: approx. 480 bhp (with air restrictors, in accordance with regulations) Max. torque: approx. 500 Nm Engine management system: Bosch MS 5.1 engine control unit, central display Transmission: Sequential 6-speed sports gearbox, operated via pneumatic shift paddles mounted on the steering wheel; 4-plate ZF Sachs carbon-fibre clutch; adjustable multi-disc limited-slip differential Front axle/rear axle: Double wishbone axle with pushrods and adjustable shock absorbers with six settings; H&R coil springs Brakes: Hydraulic dual-circuit braking system; monoblock, light-alloy brake callipers; inner-ventilated brake discs at front and rear; brake-force distribution can be adjusted by driver; electromagnetic starting valve Wheels: Forged aluminium rims; 18" x 12" front, 18" x 13" rear Tires: Hankook; front: 300-680-18, rear: 320-710-18
| Ликвидация новых запчастей по закупке | АндрейСергеевич | Продажа запчастей BMW | 2 | 02.07.2024 16:26 |
| Все опции БМВ на русском языке | Tyler | Выбираем БМВ | 21 | 19.06.2014 12:09 |
| Модельный ряд BMW пополнил автомобиль BMW 740d | Tyler | Новости BMW | 3 | 30.07.2009 19:24 |
| BMW 5 серии Gran Turismo на Женевском автосалоне 2009 | Tyler | Новости BMW | 0 | 26.02.2009 18:00 |
