BMW M4 DTM BMW M4 DTM фото Технические характеристики BMW M4 DTM Chassis: carbon-fibre monocoque with integrated tank and steel roll cage; carbon-fibre crash elements on sides; carbon fibre crash elements on front and rear Length/width/height: 4,775 mm/1,950 mm/approx. 1,200 mm Tank capacity: 120 litres Engine: 90° V8 aspirated engine, four valves per cylinder, 2 x 28.0 mm air restrictors (in accordance with regulations) Capacity: 4,000 ccm Output: approx. 480 bhp (with air restrictors, in accordance with regulations) Max. torque: approx. 500 Nm Engine management system: Bosch MS 5.1 engine control unit, central display Transmission: Sequential 6-speed sports gearbox, operated via pneumatic shift paddles mounted on the steering wheel; 4-plate ZF Sachs carbon-fibre clutch; adjustable multi-disc limited-slip differential Front axle/rear axle: Double wishbone axle with pushrods and adjustable shock absorbers with six settings; H&R coil springs Brakes: Hydraulic dual-circuit braking system; monoblock, light-alloy brake callipers; inner-ventilated brake discs at front and rear; brake-force distribution can be adjusted by driver; electromagnetic starting valve Wheels: Forged aluminium rims; 18" x 12" front, 18" x 13" rear Tires: Hankook; front: 300-680-18, rear: 320-710-18 |
| Часовой пояс GMT +3, время: 07:24. |
