BMW 525i M, 2000g.v., Podnimaetsya Temperatura jidkosti+pohodu Maslyanniy kompensator
Старый 03.06.2011, 06:26 #1
Авто: BMW 525i M, 2000
Question BMW 525i M, 2000g.v., Podnimaetsya Temperatura jidkosti+pohodu Maslyanniy kompensator
Dobroe vremya sutok uvajaemie, Podskajite pojaluista.BMW 525iM, 2000 g.v (Тип двигателя: M52).,
PROS'BA OTKLIKNUTSYA TOLKO znaushim ludyam
Vchera posle togo kak drug prokatilsya na mashine v magazin, rezko podnyalas' Temperatura, do UPORA!!!, + ko vsemu po zvuku, dumau maslyanniy kompensator poletel.
V chem prichina???
S ego slov, druga, on daje ne zametil kak podnyalas' temperatura, no tochno chto kogda on doehal do magazina, a eto lish v 5 km. ot doma, strelka bila uje do upora. Nu estestvenno, on i priehal nazad na takoi je temperature.(Da vrode pacan s opitom, a kak ne usmotrel podnyatiya T', daje ne ponimau, tem bolee chto i dvigat'sya dal'she bilo nel'zya, a on umudrilsya i nazad priehat') da eshe i konder na polnuu rabotal.
Koroche, na goryachuu, T'- na max., oboroti v norme, no stoit dat' oborotov v holostuu, kak oboroti nachinaut prigat', zaglushish, opyat' zavedesh, oboroti vrode v norme, no opyat' taki, stoit povernut' rul', kak oboroti vnov' nachinaut prigat'.
Poproboval na holodnuu, T' v norme bukval'no minuti 3, proehal 1 (odin )km. kak T' uperlas' na MAXIMUM. ZVUK POHOJIY NA stuk MASLYANNogo KOMPENSATORa PRISUTSTVUET POSTOYANNO.
K svedeniu, takogo ran'she ne bilo nikogda, daje pri Temperature vozduha +45(Dubai), i pri nagruzke v pod'em(gori)
Kak ya ponyal, drug, ne progrev kak sleduet dal na polnuu moshnost' konder, + naverno minut 5 na svetofore prostoyal, chto i privelo k probleme TERMOSTATA. izza chego estestvenno T' podnyalas' na Maximum, a izza togo chto on eshe i do doma potom doehal na MAX Temperature dvigatelya, poletel Maslyanniy kompensator.
Podskajite pojaluista v chem mojet bit' prichina ili ya ne prav???
Spasibo bol'shoe
CHIKO вне форума
Старый 03.06.2011, 13:02 #2
Аватар для m422ma
Авто: БМВ 520
Причин может быть не одна:открыть крышку радиатора попросить кого-нибудь газануть,самому смотреть идут пузырьки в жидкость,если да то это прокладка ГБЦ,2)когда температура на макс. потрогать нижний патрубок радиатора если не горячий,то это :(помпа,термостат или воздух в системе:)кстати помпа может издавать звуки.Удачи!
m422ma вне форума   Ответить с цитированием
Старый 03.06.2011, 14:46 #3
Аватар для victor540
Авто: Е39 540
Смотрите помпу - может крыльчатка провернулась на валу или рассыпалась (если пластиковая).
E39 540IA M62B44
Hyundai Accent 1,4 2008г.
Часовой пояс GMT +3, время: 09:29.
