установка черных ноздрей performance
Старый 08.10.2012, 11:32 #1
По умолчанию установка черных ноздрей performance
BMW F10 - установка черных ноздрей performance (частичный перевод с английского):
Нужна отвертка Torx-20.
Снимите резинку:
Под ней увидите 2 болта:
Теперь откручивайте 6 болтов, используя Torx-20.
Откройте защелки (поднимите вверх):
Below. Repeat on other side
Once all screws are removed you'll need to pull the center of the front bumper forward to remove chrome grilles. There's nine clips holding it to the bumper. With one hand just pull the grill out on the portion of the grill where you are pushing the clip down with your other hand.
Once both grilles are removed you'll see this.
Now time to install BMW Performance Grilles.
Side by side comparison.
Time to put everything back. The two hex bolts on top of the headlights need to be put on first before the clips/lock pins.
Then place the clip/lock pin in and press down then put lock pin in to secure.
The center piece removed in the beginning need to snap back in.
Now the extra....... Painting silver trim near the fog lights.
All you have to do to remove the mesh is take two fingers and pull forward on each corner to remove the mesh.
Unclip the three parts holding the trim to the mesh.
Paint trim with matte black or gloss spray paint. Your choice. I used matte black then reverse process and install.
Here's the completed look.
Tyler на форуме
Старый 08.10.2012, 11:45 #2
Аватар для slava657
Сказал спасибо: 113
Авто: BMW 528 e39
BMW e81/e82/e87/e88 Снятие / установка ноздрей. Tyler Сделай сам 3 31.08.2013 20:25
Линейка продуктов BMW Performance для BMW 3 серии Tyler Новости BMW 0 16.06.2009 13:10
Часовой пояс GMT +3, время: 16:12.
