-   Сделай сам (https://bmwpost.ru/forum/sdelai-sam-8/)
-   -   BMW F20 установка держателя для iphone (+ протяжка кабеля до приборки) (https://bmwpost.ru/forum/sdelai-sam-8/ustanovka-derzhatelya-dlya-iphone-protyazhka-kabelya-do-priborki-21655/)
Tyler 17.10.2012 01:14
BMW F20 установка держателя для iphone (+ протяжка USB-кабеля из подлокотника до приборки)
Необходимое:
  1. Dashboard mount [Ссылки могут видеть только зарегистрированные пользователи. Зарегистрироваться...]
  2. Phone mount (attaches to dashmount and holds phone) [Ссылки могут видеть только зарегистрированные пользователи. Зарегистрироваться...]
  3. STAR T20 Screwdriver
Инструкция:
  1. Шаг 1: Снимите вентиляционные решетки на панели
    In this step, which is not as easy as a certain youtube video would suggest, we remove the center console vents. I did this by gripping the top right of the vent and getting my fingers under and unsnapping it, then i ran my fingers along to unsnap the left hand side. As seen below:
    I then ran my fingers down from the leftside to finally unclip the vents:
    At this point you can safely rest the vents on the centre console, it wont damage or scratch anything
  2. Step 2: Remove the passenger side T20 (STAR) screw
    Below you can see the screw which needs removing, this was simple, although a little effort was required- so make sure you use the correct bit, or you'll bald the head.
  3. Step 3: Insert the dashboad mount
    At this stage, i was a little worried as i couldnt figure out how to get the mount in. Turns out you simply need to slide it down between the dashboard and the CD unit as shown in the image below. ensure you align the screw hole with the screw hole in the dash
  4. Step 4: Reassemble
    Reassemble by screwing the T20 screw back in (nice and tight so everything comes together), and snap the vents back onto the dash
  5. Step 5: Attach your chosen phone bracket
    I used my brodit dock from my previous car, but you can attach whatever you wish. Any brodit dock works with this solution. The great thing about brodits is that its on a cylinder adjustable- so it can be rotated any direction to suit your needs
  6. Step 5: Admire work
    Congratulations, you now have a convenient way to access your phone. I'll post up how i routed my USB cable to the arm rest, if i ever get around to it:
Tyler 17.10.2012 01:15
Прокладка USB-кабеля
Необходимое:
  • iPhone Y кабель - BMW номер 61120440812
  • Dock Extender Extension Cable (This is the one i purchased, and thus know works) [Ссылки могут видеть только зарегистрированные пользователи. Зарегистрироваться...]
  • Philips Screwdriver
  • File (not for your car, dont worry [Ссылки могут видеть только зарегистрированные пользователи. Зарегистрироваться...])
  • Picture frame wire, or simmilar - you can get this from any good DIY store- the key is that it is fairly strong and long
Инструкция
  • File the iPhone dock
    The first problem i encountered was the USB extender cable end was too big to fit in the iPhone dock. I had to file it down to make it fit- Make sure the dock fits flush with the mount.
  • Locate and prep the arm rest
    You must first pull out the rubber tray inside the arm rest. This is crucial to routing the USB cable
    Slip your finger nail in the grove, and push your finger in
    Grip with your finger and pull it out
  • Feed the USB cable into the arm rest
    You must feed the female end of the USB cable up through and into the arm rest. Do this by forcing the connector between the upolstory and dashboard- it will fit through. Then push the cable through, and you will see it through the rectangle in the centre of the arm rest. Put your fingers in there and pull it through.
    You will end up with this
    Install the Y adapter and connect to the female end of the USB extender
    Push the slack cable down and re-insert the rubber tray
    You will now end up with the some slack USB cable, and a male end
  • Lay the USB down the centre console
    Locate the working area
    Slide your fingers between the upolstory and the dashboard, lifting it gently away
    You will notice when you release, the dashboard fits back without any problems
    Insert the slack cable into the gab pade by your fingers and push it up
    The cable will then be swallowed up behind the console
    Push the remaining cable under and the cable will be hidden
    Here is what the result is- make sure that the cable is taught as possible at this moment, ensuring that you have as much cable as possible
  • Route the cable up the dashboard
    Take you're picture frame wire and feed it into the the hole in the dash, and down towards the passenger footwell
    Then push your fingers up into the dashboard in the passener footwell. it's fiddley, but you will get it eventually
    Wrap the wire around the end of your extension cable, then tuck it inside of the dashboard and pull the cable up from the other end, slowly, until the cable appears (sorry for the lack of pictures here- i will update with propper pics tonight- i only just did this on the car park at work)
    Re-attach the vents- make sure you keep the cable in the corner of the vents, and you will end up with this:
    Note that the small gap is not noticeable, even with this thick USB cable, the vents snap back in and are sealed- as on a max air con, there is no leaked air detected, and the small gap cannot be seen due to the docks position
  • Attach the dock to the dashboard
    The final peice. Reattach the dock and tidy up
inside001bmw 27.10.2015 09:34
:super:
Часовой пояс GMT +3, время: 16:12.
