| Сделай сам Самостоятельно меняете масло, фильтры? Устанавливаете чейнджер? И т.п. Поделитесь полезной информацией. Коллекция фототчётов по ремонту и ТО автомобилей BMW и Mini. В этом разделе только отчёты. Вопросы задавайте в разделе "Ремонт BMW и эксплуатация" |
| | #1 |
Поблагодарили 10,616 раз(а) в 1,958 сообщениях
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки |
На картинках процесс установки накладок на педали M Performance на BMW F30 - M Performance накладки на педали (#35002232278 для автомобилей с АКПП) Набор накладок: Стандартные педали: Сначала снимаем резиновые накладки: Сверлим отверстия: After all the holes are drilled, you can put the rubber M pedal cover on and then place the stainless steel part on and thread the bolts through attach the nuts to the other side. As mentioned earlier, the bolts are a STAR PATTERN and NOT PHILLIPS. Here is a picture of the bit I used: On to the next pedal, go ahead and take the time to clean the stock plastic pedal to ensure good adhesive contact. The M gas pedal has an adhesive backing that has two screws that screw directly into the gas pedal. We just have to drill some small pilot holes for the screws to thread into first. So go ahead and practice putting the M gas pedal on and see how it lines up because I believe once you stick it to the pedal you won't be able to remove it. Now that you see how it lines up, go ahead and remove the adhesive backing: Find a drill bit that is slightly SMALLER than the screws provided. If you drill this too big, the screw threads will not grab to the plastic and you have wasted your time. With the correct drill bit selected, go ahead and drill some pilot holes. Once they are drilled, go ahead and use the star pattern screw bit and screw them into the stock gas pedal. Your completed product should look similar to this: And here with my rubber floor mats placed back in to complete the look:
| BMW e34 | Tyler | 5-er | 22 | 05.08.2017 13:49 |
| Все опции БМВ на русском языке | Tyler | Выбираем БМВ | 21 | 19.06.2014 12:09 |
| BMW e28 | Tyler | 5-er | 10 | 17.01.2013 17:51 |
| Линейка продуктов BMW Performance для BMW 3 серии | Tyler | Новости BMW | 0 | 16.06.2009 13:10 |
| Снятие и установка / замена датчика положения педали (М62, М54) | Tyler | 12 Электрооборудование двиг-ля | 0 | 14.04.2009 11:14 |
