установка противотуманок
Старый 30.08.2014, 00:17 #1
Поблагодарили 10,622 раз(а) в 1,958 сообщениях
По умолчанию установка противотуманок
Инструкция по установке противотуманок на BMW F30. Противотуманные фары от BMW F32
Номера:
63 17 7 315 559
63 17 7 315 560
Нужно - T25 Torx
Here you see the wheel has been removed and shows the small bolts to be removed to gain access. The arrow shows the location of one more bolt out of the picture frame.
You are doing this to move the fender liner out of the way.
This shows the location of the two screws(T25) holding the light in place, remove them, then disconnect the wire harness.
the following just shows the difference between the lights
Yes I know the new light looks bigger in the photo, it is but not by much, there is more than enough room in the area.
Plug wiring harness in the new light, install, and secure with the two screws and put car back together. The passenger side is the same no unexpected surprises other than a dead bug or two.
I suppose you could do this without removing the wheels, by just taking off the grill in front of the fog lights(it just pulls off), and using a mirror to visualize the two mounting screws, it just needs a little more patience.
Final result.....
+ требуется закодировать.
Tyler на форуме
Снятие и установка автоматической коробки передач (A5S 360R/ 390R) Tyler 24 АКПП 1 02.09.2009 19:00
Снятие и установка, уплотнение или замена нижней части блока ГРМ (М43 / M43TU) Tyler 11 Двигатель 0 29.05.2009 14:52
Снятие и установка / замена сцепления (SAC 240 /4 цил. Только M47TU/T2, 6, 8 цил.) Tyler 21 Сцепление 0 20.04.2009 09:50
Часовой пояс GMT +3, время: 10:44.
