-   Сделай сам (https://bmwpost.ru/forum/sdelai-sam-8/)
-   -   BMW e46 Установка в BMW e46 руля с обогревом от X3 (https://bmwpost.ru/forum/sdelai-sam-8/ustanovka-v-bmw-e46-rulya-s-obogrevom-ot-x3-5681/)
Tyler 21.03.2010 00:24
Нашёл инструкцию по установке в BMW e46 руля с обогревом от BMW X3. Язык - английский и инструкция очень подробная и объёмная, но, если кому непонятно что-то, пользуемся google-переводчиком или задавайте вопросы - переведу.
Установка руля с обогревом в BMW e46 330 от BMW 2006 X3 - подробный фото/видео-отчёт:
Часть 1: Вступление
This DIY was a lot easier than I anticipated. The E46 Steering Wheel and Slip Ring plug and play design makes the swap over to the X3 Heated Wheel fairly easy. With only a T30 Torx Screw Driver and Slim Ratchet to remove the airbag and a 5/8" socket on a long handle ratchet to remove the wheel you can swap the wheel out with in 30 minutes. And the Slip Ring is attached by 4 smaller Torx Screws. This part should take about another 30 minutes to a hour.
You MUST UNPLUG your battery before removing the airbag (so as to not set off the air bag and/or the airbag warning lamp during the DIY).
Again I was lucky to come across an complete X3 heated wheel that was no longer needed by it's former owner. Previous DIYs used Steering Wheels from early years E38 and E39. At this time, I highly recommend just getting an 2002+ X3 or X5 heated wheel. Those earlier E38 and E39 wheels had single stage airbags and bulb lit icons on the steering wheel buttons that don't get powered well and appear dim and off color in the E46 or newer BMWs that use LED lit icons on the steering wheel buttons. So getting an X3 or X5 wheel is a safe bet. Also you can get a complete X3 / X5 heated wheel on **** within the $150 to $300 range.
This picture here shows the two types of X3 / X5 steering wheel. For this DIY you will need the wheel with the heated wheel icon and two wavy arrows pointing up on the button pod below the Cruise Control buttons. The other one with the circle of arrows icon for the AC recirculation and will not work in this retrofit.
[Ссылки могут видеть только зарегистрированные пользователи. Зарегистрироваться...]This image has been resized. Click this bar to view the full image.[Ссылки могут видеть только зарегистрированные пользователи. Зарегистрироваться...]
I also lucked out with my Slip Ring acquisition. The Slip Rings do not have any set part numbering and according to the BMW P/N manifest all slip rings from the 1995 E38 7 series thru the current X3 models seem to have 1 shared part number regardless of if the slip ring is for SMG or Heated Steering Wheels. My best bet was just asking around for the slip ring from a heated steering wheel until I found found. It took me about 2 weeks to get the slip ring after I got the wheel and that delay was mainly due to the lack of specific parts number for the slip rings.
A great seller on **** "Scubaa1" aka Scuba Steve hooked me up with the slip ring from a 2001 7 series for only $35 w/ free shipping and it arrived quickly and in mint condition. I totally recommend seeking him out for BMW parts as I will also use him in the future over those Junk Yard sellers out of CA that charge you Dealership prices for dirty used parts.
These are intro pictures of the wheel and it's parts as well as two more videos explaining all the elements of this retrofit.
Two videos introducing everything you need to know about the heated steering wheel and slip ring that BMW uses.
Tyler 21.03.2010 00:29
Часть 2 - снимаем руль:
This part is fairly easy and straight forward. For sport wheels with the round or triangular air bags the placement of the air bag bolts may be different.
JUST REMEMBER THAT YOUR BATTERY MUST BE COMPLETELY UNPLUGGED BEFORE TAKING THE AIRBAG OFF!!!!
Tyler 21.03.2010 00:43
Часть 3. Установка нового контактного кольца и руля с обогревом.
Tyler 21.03.2010 00:45
Часть 4. Adding Power/Ground to Heated Wheel and Finishing Touches
Comparing the LED brightness and hue between the E46 and heated X3 wheel. There is a slight difference
and I can't quite nail it down but it is hardly noticable.
The LED lets you know when the wheel heater is on and off.
I like this indicator because it reminds you to turn it off if you no longer need it whiles driving.
Congrads! Go enjoy your new wheel!
Slitch 21.03.2010 10:19
хочу себе на E36 такой руль. кто знает номер контактной группы? и кто подобное делал?
Часовой пояс GMT +3, время: 05:49.
