BMW Coding Tool
Старый 08.05.2012, 11:01 #1
Аватар для nickbet
Сказал спасибо: 79
По умолчанию BMW Coding Tool
парни, привет, а че за програмка, может кто обьяснит
Тип файла: zip BMW Coding Tool v230.zip (415.1 Кб, 2047 просмотров)
nickbet вне форума
Сказал Спасибо nickbet за это сообщение:
RastaRen420 (21.10.2025)
Старый 08.05.2012, 12:21 #2
Аватар для RUSTAM Range
Сказал спасибо: 20
Поблагодарили 19 раз(а) в 2 сообщениях
Авто: BMW 740
Поддерживаю! Тоже очень интересно.Я ее уже на форуме выкладывал,но ответа небыло(((((
RUSTAM Range вне форума   Ответить с цитированием
Старый 08.05.2012, 13:08 #3
When you code your car with NCS Expert, you have to follow several steps after reading the ecu:
You have to open the WORK folder, open FSW_PSW.TRC in notepad, make the changes in this file, save it as FSW_PSW.MAN, copy the FSW_PSW.TRC and rename to have a backup.
These steps can be done with this program, just to make it a bit easier...
Short description:
Button "Load TRC-file"
file loaded is ...\NCSEXPER\WORK\FSW_PSW.TRC
Select the line with the value you want to change
--> change the value in the popup screen
or choose Show values for all possible values and select one
Button "Save MAN-file"
modified file is saved as ...\NCSEXPER\WORK\FSW_PSW.MAN
--> enter a name for the backup file of the original trc and man-file
Also updating of new SP-daten files is a lot of copy, paste and adjusting files. Manual and/or with Total Commander.
These steps can also be done with this program... with 1 button...
Short description:
Button "Select SP-source"
Select the folder with the new SP daten
Button "Update SP-daten"
Only all NEWER files will be copied from:
...\SP-DATEN-Exx\ECU --> ...\EDIABAS\ECU
...\SP-DATEN-Exx\SGDAT --> ...\EC-APPS\NFS\SGDAT
...\SP-DATEN-Exx\SGDAT --> ...\NCSEXPER\SGDAT
...\SP-DATEN-Exx\DATEN --> ...\NCSEXPER\DATEN\Exx
also update of files in ...\NCSEXPER\DATEN
Button "Update WinKFP"
All folders will be copied and replaced from:
...\SP-DATEN-Exx\DATA --> ...\EC-APPS\NFS\DATA
also update of SGIDC.AS2 in ...\EC-APPS\NFS\DATA\GDATEN to adjust the "long lines"
backup's of all folders are saved as ...\name_date_time
** NEW VERSION **
Updates version 2.1.0
Extra option to show all possible values of all functions in the TRC-file. You first have to select your chassis and module. After that just select one value to change.
(The popup screen to change directly without showing all values is still there...)
Extra option to show English translation. The program is compatible with the file Translations.csv of NCS Dummy. Thanks to revtor.
(Translations.csv must be in the same path as BMW Coding Tool.exe)
Extra coding log. When you save the MAN-file the changes you made will be saved in Codinglog.txt.
Extra options in File menu:
- Load non-default TRC-file (for example a backup-file)
- Save the default TRC-file (without loading or changing)
- Empty the MAN-file
The program window is now full resizable (for low-res netbooks). Update SP-daten is possible now without the DATA folder (v45?). Improved search function.
Updates version 2.2.0
Backup both trc and man file is possible now.
The clean install of SP-daten bug is fixed.
The open work dialog default directory is fixed.
Resized the main window for better view on low-res netbooks.
Improved backup function: select your backup folder, add folders and name as you wish.
Extra option in File menu:
- Compare files: select file 1 and file 2 to trace differences
Updates version 2.3.0
Improved search function: partial search, direction up or down. The search dialog is top-most now, so scrolling the list and change values is possible without closing the search dialog. Also added F3 for search next.
Improved change value dialog: added a "quick change" checkbox for switching between aktiv <--> nicht_aktiv without typing.
Fixed the startup positioning bug and some other things.
Extra options in Settings menu:
- Show NCS coding only (hides the SP daten update part)
- Set custom picture (set a picture you like... click on the picture for more...)
Updates version 2.4.0
Fixed a bug in search function.
Extra feature to check for ECU updates. Just enter the assembly (zusb) number and the dialog will show you the update available.
Included: comdlg32.ocx and Translations.csv
Please try this program and let me know any comments and suggestions to make it better !
Тип файла: zip BMW Coding Tool v240.zip (419.1 Кб, 774 просмотров)
Eduardoprobe likes this.
eric (10.07.2012), nickbet (08.05.2012), ultimatebmw (24.06.2012), vanovanos (16.11.2012)
Старый 08.05.2012, 13:20 #4
Аватар для nickbet
Сказал спасибо: 79
Алексей, добрый день, хоть в двух словах на русском, обьясните пожалуйста,
nickbet вне форума   Ответить с цитированием
Старый 08.05.2012, 13:26 #5
Аватар для БУКА
Авто: Compot уехал =)
Когда вы код вашего автомобиля с НСУ Эксперт, вы должны выполнить несколько шагов после прочтения ЭКЮ:
Вы должны открыть в рабочей папке, откройте FSW_PSW.TRC в блокноте, внести изменения в этот файл, сохранить его в FSW_PSW.MAN, скопируйте FSW_PSW.TRC и переименовать, чтобы иметь резервную копию.
Эти шаги можно сделать с помощью этой программы, просто, чтобы сделать его немного легче...
Краткое описание:
Кнопка "Загрузить TRC-файл"
загружаемый файл ...\NCSEXPER\РАБОТА\FSW_PSW.TRC
Выберите строку со значением, которое вы хотите изменить
-- > изменить значение в раскрывающемся экран
или выберите Показать значений для всех возможных значений и выберите один
Кнопка "Сохранить ЧЕЛОВЕКА-файл"
измененный файл будет сохранен как ...\NCSEXPER\РАБОТА\FSW_PSW.MAN
-- > введите имя для файла резервной копии оригинала КИП и человек-файла
Также обновление нового СП-daten файлов много копирование, вставка и Настройка файлов. Вручную и/или с Total Commander.
Эти действия также может быть сделано с помощью этой программы... с 1 кнопка...
Краткое описание:
Кнопка "Выбрать SP-источник"
Выберите папку с нового СП daten
Кнопка "Обновить SP-daten"
Только все НОВЫЕ файлы будут скопированы из:
...\SP-DATEN-Exx\ЭКЮ -- > ...\EDIABAS\ЭКЮ
...\SP-DATEN-Exx\SGDAT -- > ...\EC-APPS\NFS\SGDAT
...\SP-DATEN-Exx\SGDAT -- > ...\NCSEXPER\SGDAT
...\SP-DATEN-Exx\ПАРАМЕТРЫ -- > ...\NCSEXPER\ПАРАМЕТРЫ\Exx
также обновление файлов ...\NCSEXPER\DATEN
Кнопка "Обновить WinKFP"
Все папки будут скопированы и заменены:
...\SP-DATEN-Exx\DATA -- > ...\EC-APPS\NFS\DATA
также обновление SGIDC.AS2 в ...\EC-APPS\NFS\DATA\GDATEN для того чтобы отрегулировать "длинных линий"
резервное копирование всех папок сохраняются в ...\name_date_time
* * НОВАЯ ВЕРСИЯ **
Обновления версии 2.1.0
Дополнительный параметр для отображения всех возможных значений всех функций в КИП-файл. Сначала вы должны выбрать ваш корпус и модуль. После этого просто выберите один значение для изменения.
(Всплывающий экран для изменения непосредственно, не показывая все значения еще есть...)
Дополнительную опцию, чтобы показать перевод на английский язык. Программа совместима с файловой Translations.csv НСУ Манекен. Благодаря revtor.
(Translations.csv должно быть по тому же пути, как BMW Кодирования Tool.exe)
Дополнительный код, журнал. Когда вы сохраните ЧЕЛОВЕК-файл все внесенные изменения будут сохранены в Codinglog.txt.
Дополнительные опции в меню " Файл":
- Груз не по умолчанию TRC-файла (например, архива-файл)
- Сохранение по умолчанию TRC-файл (без загрузки или изменение)
- Пустой ЧЕЛОВЕК,-файла
Окно программы теперь полностью расширяемое (для low-res нетбуков). Обновления SP-daten сейчас можно без папки DATA (v45?). Улучшены функции поиска.
Обновления версии 2.2.0
Резервное копирование КИП и человек файла возможно сейчас.
На чистой установке SP-daten ошибка Исправлена.
Открытое работы диалоговом окне default directory будет Исправлена.
Изменить размер главного окна для лучшего просмотра на low-res нетбуков.
Улучшенные функции резервного копирования: выберите папку резервного копирования, добавлять папки и имя, как вы хотите.
Дополнительная опция в меню " Файл":
- Сравнение файлов: выберите файл 1, файл 2, чтобы проследить различия
Обновления версии 2.3.0
Улучшена функция поиска: частичный поиск, направление вверх или вниз. Диалоговое окно поиска топ-сейчас большинство, так прокрутки списка и изменить значения можно, не закрывая диалоговое окно поиска. Также добавил F3 для поиска следующего.
Улучшено диалоговое окно изменить значение: добавлены "быстрые перемены" флажок для переключения между aktiv < -- > nicht_aktiv без ввода.
Исправлена автозагрузки позиционирования ошибка, и некоторые другие вещи.
Дополнительные опции в меню Настроек:
- Показать НСУ кодирования (только скрывает SP daten обновления части)
- Установить custom picture (Настройка изображения, вы как... нажмите на картинку для получения более...)
Обновления версии 2.4.0
Исправлена ошибка в функции поиска.
Дополнительные функции для проверки ЭКЮ обновления. Просто введите Ассамблеи (zusb) номер и диалог покажет вам доступные обновления.
Включены: comdlg32.ocx и Translations.csv
Пожалуйста попробуйте эту программу и дайте мне знать, любые комментарии и предложения, чтобы сделать его лучше!
BMW 3 series (E36/4)
BMW 3 series (E36/5)
Эти 4 пользователя(ей) сказали Спасибо БУКА за сообщение:
control77 (05.03.2014), DimaIce2 (14.02.2014), eric (10.07.2012), nickbet (10.05.2012)
Старый 08.05.2012, 13:26 #6
nickbet, привет.
Автор программы говорит (судя по описанию), что должно упростить процесс работы с NCSExpert и обновления его, а также winkfp (меньше кнопок жать и меньше думать).
По функционалу, естественно, ничего нового.
eric (10.07.2012), nickbet (10.05.2012), RUSTAM Range (08.05.2012)
Старый 23.05.2013, 20:06 #7
Аватар для Витюха
Сказал спасибо: 100
Авто: трактор
Не знаю какая сейчас версия....но пусть тут будет и эта...
Эти 7 пользователя(ей) сказали Спасибо Витюха за сообщение:
dimakomer (05.06.2013), iv-z2005 (23.01.2014), NURGAZY (07.11.2014), oleg tool (26.05.2013), RastaRen420 (21.10.2025), Sergei1966 (20.12.2013), traktorist999 (17.02.2017)
Старый 04.09.2013, 10:17 #8
Авто: BMW X5 E70 2009
Я этой штукой пользуюсь, чтобы DATEN обновлять. Файлов много, руками запарно. А тут в два клика, удобно.
legulatol вне форума   Ответить с цитированием
Сказал Спасибо legulatol за это сообщение:
skydes (05.07.2014)
Старый 04.09.2013, 13:30 #9
Сообщение от legulatol Посмотреть сообщение
Про LADEN.BAT не слыхал?
Старый 04.09.2013, 14:16 #10
Аватар для Busyman
Сказал спасибо: 33
Поблагодарили 134 раз(а) в 108 сообщениях
слышал писали что косячит в обновлении.... делаю по старинке ручками...))
Online help
Помощь онлайн
Любые вопросы связанные c BMW
ЛС
Busyman вне форума   Ответить с цитированием
Сказал Спасибо Busyman за это сообщение:
Furg0n (11.12.2014)
Часовой пояс GMT +3, время: 01:59.
