Замена масла N55 в картинках
Старый 15.01.2012, 16:03 #1
По умолчанию Замена масла N55 в картинках
chock rear wheels
I used two floor jacks with plastic pads to keep from damaging plastic jack points on the F103.
Use jacks stands in case floor jacks malfunction (this is VERY IMPORTANT) Never get under a car without proper safety backup.
Remove small bolt that holds trap door in place, remove trap door.
5. Using 17mm socket and wrench loosen drain plug. (Bolt faces down, so no mess with angle draining)
I sucked out all the residual oil in the filter seat with a turkey baster.
Match the green alignment marks (thanks for that Dingolfing!)
zalimhan74 (11.04.2015), ААА-84 (02.11.2013)
Часовой пояс GMT +3, время: 00:20.
