Тема: BMW Inpa/Ediabas
Старый 20.03.2011, 21:03 #768
  • Ещё 2 документа по кодированию BMW. Когда будете смотреть, ставьте масштаб побольше.
Содержание:
welcome light on when unlocking the car WL_RL_BL
Adaptive Headlight Error CHECK_SMC_ERROR
Alarm beep on lock QUIT_AKUST_SCHAERF
Alarm beep on unlock QUIT_AKUST_ENTSCH
All High Beams PWM_WERT2_FL_BIXENON
Angel Eyes Error: need to code all the following FEHLERMELDUNG_CC_SL_V_L
Angel Eyes Error: need to code all the following FEHLERMELDUNG_CC_SL_V_R
Angel Eyes Error: need to code all the following KALTUEBERWACHUNG_SL_V_L
Angel Eyes Error: need to code all the following KALTUEBERWACHUNG_SL_V_R
Angel Eyes Error: need to code all the following WARMUEBERWACHUNG_SL_V_L
Angel Eyes Error: need to code all the following WARMUEBERWACHUNG_SL_V_R
Angel Eyes on when unlocking the car WL_SL_1
Audio System Audio System
Auto Dim Mirrors SPIEGEL_ELEKTROCHROM
Auto Headlight Sensitivity adjustement from BC Button LICHT_AUT_WERT_1, LICHT_AUT_WERT_2, LICHT_AUT_WERT_3
Auto Light Sensitivity Control in Idrive (Multiple Changes required, see Description) RAIN_LIGHT_SENSOR
BFD with Regular Brake Light BREMSL_FKT_MIT_BFD
Bulb Testing Warning KALTUEBERWACHUNG_AL
Bulb Testing Warning KALTUEBERWACHUNG_BL_MI
Bulb Testing Warning KALTUEBERWACHUNG_BLK_HI
Bulb Testing Warning KALTUEBERWACHUNG_BLK_VO
Bulb Testing Warning KALTUEBERWACHUNG_FL
Bulb Testing Warning KALTUEBERWACHUNG_KZL
Bulb Testing Warning KALTUEBERWACHUNG_KZL_LI
Bulb Testing Warning KALTUEBERWACHUNG_NSW
Bulb Testing Warning KALTUEBERWACHUNG_RL
Bulb Testing Warning WARMUEBERWACHUNG_AL
Bulb Testing Warning WARMUEBERWACHUNG_AL_L
Bulb Testing Warning WARMUEBERWACHUNG_BL_MI
Bulb Testing Warning WARMUEBERWACHUNG_BLK_HI
Bulb Testing Warning WARMUEBERWACHUNG_BLK_VO
Bulb Testing Warning WARMUEBERWACHUNG_FL
Bulb Testing Warning WARMUEBERWACHUNG_KZL_LI
Central Locking with Key Only ENTSICHERN_CENTERLOCK
Climate don't turn ON in Auto mode KLIMA_MIT_AUTO_0
Climate don't turn ON in Auto mode KLIMA_MIT_AUTO_1
Climate don't turn ON in Auto mode KLIMA_MIT_AUTO_10/15
Climate don't turn ON in Auto mode KLIMA_MIT_AUTO_2
Close Windows/Roof KOMFORTSCHLIESSUNG_FB
Close Windows/Roof KOMFORTSCHLIESSUNG_PA
Corner Delete Mod PO_RL_FKT_MIT_SL_V
Corner Delete Mod PWM_SL_V_BEI_AKTIVEN_AL
Corner Delete Mod SIDEMARKER_US
Corner Delete Mod SIDEMARKER_US_MIT_FRA_V
Corner Delete Mod SIDEMARKER_US_NFRM
Corner LED Delete Mod PWM_FL_ALS_CORNERLIGHT
Corner LED Delete Mod PWM_POL_BEI_AKTIVEN_AL
Corner LED Delete Mod PWM_POL_BEI_AKTIVEN_FL
Corner LED Delete Mod SL_FKT_MIT_POL
Corner LED Delete Mod E92 PO_RL_FKT_MIT_SL_V
Corner LED Delete Mod E92 PWM_SL_V_BEI_AKTIVEN_AL
Corner LED Delete Mod E92 PWM_SL_V_BEI_AKTIVEN_FL
Corner LED Delete Mod E92 sl_bl_ers_def_rl_bl_1
Corner LED Delete Mod E92 SL_V_PO_RL_FKT
Corner LED Delete Mod E92 WL_POL
Instant MPG DIGITAL_KVA
Digital Speed BC_DIGITAL_V
Disable iDrive Disclaimer LEGAL_DISCL
Disable iDrive Disclaimer LEGAL_DISCLAIMER_TIME
Disable windows safety feature FH_TUERAUF_STOP_MAUT_3R
Disable windows safety feature TUERAUF_STOP_MAUT
Display and Gong when Key in ignition ZUENDSCHLUESSEL_WARNUNG
Door Dong CC_ZUENDSCHLUESSEL
Double Blink Hazards in crash DOPPELBLINKIMPULS_CRASH
Double Blink Hazards when button is pressed DOPPELBLINKIMPULS_WARNBLK DRL
High Beam Delete DRL_V_GEDIMMT DRL
High Beam TAGFAHRLICHT_ECE_1
DRL option in iDrive DAY_RUN_LIGHT_CCC
DRL option in iDrive DAYDRIVING_LIGHT
DRL Taillight Delete DRL_TFL_MIT_RL_BL_2
DRL Taillight Delete DRL_TFL_MIT_SL_2
DRL Taillight Delete RL_BL_2_MIT_TFL
DVD Playback VIDEO_NUR_MIT_HANDBREMSE
DVD-In Motion VIDEO_DENY_C0B
Eject Key Fob with Engine Off KOMFORT_EJECT
Digital Speed Value V_DIGITAL_KORRECTOR
Enable DRL TAGFAHRLICHT_ECE_1
Enable DRL VERHALTEN_DRL_TFL
Enable Shift Suggestion in 6MT SP_ANZEIGE, SCHALT_PKT_BC, SCHALT_PKT_DAUERHAFT
Engine Start ANLASSSPERRE_BLS
Fog Lights + Flash LH_UND_NSW_NICHT_GLEICHZ
Fog Lights + High Beam FL_UND_NSW_NICHT_GLEICHZ
Fold Mirror ASP_KOMFORT_EINKLAPP
Fold Mirror SPIEGEL_KOMFORT_EINKLAPP
Front corner LED lights on when unlocking the car WL_POL_3R
Front fog lights on when unlocking the car WL_NSW
Front Parking lights on when unlocking the car WL_SL_2
Front turn signals on when unlocking the car WL_BLK_V
Fuel Stop Suggestion in Route Guidance NAVI_FUELSTOP_PROPOSAL
Headlight Washers Disabled SCHEINWERFERREININUNG
High beams on when unlocking the car WL_FL
iDrive Default Screen Communication VA_FB_COMMUNICATION
iDrive Default Screen Entertainment VA_FB_ENTERTAINMENT
iDrive Default Screen Navigation VA_FB_NAVIGATION
iDrive Display Modes NAVI_MAPMODE_AUTOMATIC
LED Tail Light Retrofit CC_MELD_BFD_BL
LED Tail Light Retrofit FEHLERMELDUNG_CC_BFD_L & R
Length of time that Welcome Lights Stay on WL_DAUER
Lock/unlock beep option in iDrive (part 1) ACOUSTIC: aktiv
Lock/unlock beep option in iDrive (part 2) C941C_QUITT_AKUST_KLAPPE: fkt_frei
Lock/unlock beep option in iDrive (part 3) K9416_QUITT_AKUST_ENTSCH: fkt_frei
Lock/unlock beep option in iDrive (part 4) C9413_QUITT_AKUST_SCHAERF: fkt_frei
Low beams on when unlocking the car WL_AL
Panic Mode
Rain Close from full open REGENSCHLIESSEN
Rain Close Sunroof from Tilt REGENSCHLIESSENTILT
Rear fog lights on when unlocking the car WL_NSL
Rear license plate on when unlocking the car WL_KZL
Rear turn signals on when unlocking the car WL_BLK_H
REST feature enable on cars with an ALL button REST_TASTE_VERBAUT
Right Parking lamp malfunction error message FEHLERMELDUNG_CC_SL_V_R
Seat Belt Chime SBR_BEIFAHRER_1
Seat Belt Chime SBR_BEIFAHRER_2_CD
Seat Belt Chime SBR_FAHRER_1
Sound alarm chirp level BUZZER_HIGH_LEVEL
TPMS Disable $2vb
Unlock Doors ER_KEYOUT_AUTOVR
Wiper wipes to End position after turning engine off ZYCLUS_VOLLEND_KLR_AUS
Xenon Headlight Retrofit (from Halogen to OEM Xenon) 522
Подробности в файле.
Тип файла: pdf www.bmwpost.ru_BMW_E9x_Code_List.pdf (335.5 Кб, 461 просмотров)
Тип файла: pdf www.bmwpost.ru-BMW-E-Series-Coding.pdf (279.5 Кб, 125 просмотров)
Эти 7 пользователя(ей) сказали Спасибо Tyler за сообщение:
eric (05.12.2012), Gregory57 (17.09.2011), iv-z2005 (05.07.2012), KOL151 (13.06.2012), skomi (08.07.2011), Ural (29.06.2011), Zeke (30.06.2011)
