Старый 01.04.2011, 09:18 #90
Аватар для BMWFan
Сказал спасибо: 39
3.5 IFH-0009: ECU isn’t connected or doesn’t respond
Reason 1: In the Ediabas.ini file, the interface is set to STD:ADS. However, you have
connected an OBD connector.
Solution 1: Modify the interface setting.
Reason 2: The ignition is switched off.
Solution 2: Switch the ignition on.
Reason 3: The device manager has been used to disable the FIFO buffer for COM1.
Solution 3: In the device manager (Windows XP: Enter “Start” ￿ “Control Panel” ￿
“System” ￿ “Hardware” ￿ “Device Manager” ￿ Ports (COM & LPT)), and select
COM1 from the ports and under the “Port Settings” tab, select “Advanced”. There
must be a check-mark by “Use FIFO buffers” and the highest possible setting
must be selected for the receive buffer.
1 отпадает, 3-его на вин7 не нашёл, остаётся 2
или корявый винкфп 5.1.6/данные от исты 40
Последний раз редактировалось BMWFan; 01.04.2011 в 09:38.
BMWFan вне форума   Ответить с цитированием
