- Open Daemon Tools Lite and mount c:\ISTA_P_V38\ISTA_P_2.38.0_Disk1_3.iso. On my machine, it's mounted onto drive F: but it may be different on your machine. If so, you'll need to change F: to the mounted drive on your machine in the below instructions.
- Open a command window (press Windows key+R to bring up run menu, type cmd and press return)
- Type
md C:\BMW
md C:\BMW\ISTA_V38
cd C:\jetunpack
jetunpack F:\ISTA-P-AInst_38.0.0_--.jetarch c:\BMW\ISTA_V38\
jetunpack F:\ISTA-P-Client_38.0.0_--.jetarch C:\BMW\ISTA_V38\
- Open Daemon Tools Lite and unmount the iso. Mount c:\ISTA_P_V38\ISTA_P_2.38.0_Disk2_3.iso
- Go to the command window and copy ISTA-P-Server_38.0.0_--.jetarch.part1 and version.ini to your c:\jetunpack directory
copy F:\*.* .
- Open Daemon Tools Lite and unmount the iso. Mount c:\ISTA_P_V38\ISTA_P_2.38.0_Disk3_3.iso
- Go to the command window and copy ISTA-P-Server_38.0.0_--.jetarch.part2 to your c:\jetunpack directory
copy F:\ISTA-P-Server_38.0.0_--.jetarch.part2 .
- Now you're ready to unpack the final 2 files. Type
jetunpack ISTA-P-Server_38.0.0_--.jetarch C:\BMW\ISTA_V38\
This is going to take a while so be patient.
