Старый 30.04.2011, 22:33 #1
По умолчанию Патч для драйвера ADS
Может, кому пригодится...
Make ADS interface work with PCMCIA-Serial adapters
PROBLEM: The ADS diagnostic interface for BMW cars is infamous for requiring a "real" serial port and not working with PCMCIA and USB adapters. Serial ports are quite rare on modern laptops.
ANALYSIS: The ADS interface uses a driver that bypasses Windows settings and targets the default hardware address of COM1 directly. Virtual serial ports have a different hardware address (or in case of USB an entirely different access mechanism) - therefore they don't work.
Решение - в приложенном файле.
The tool will patch your ADS driver to target a different COM port address - this means that it can be used with standard PCMCIA adapters, but not USB adapters.
To see the hardware address of your virtual COM port:
- open the Device Manager window
- right-click on your virtual COM port device
- select Properties
- go to the Resources tab (if there is none, the device probably doesn't have a hardware address and you are out of luck)
- write down the first number from the I/O range (something like "03F8")
Тип файла: zip www.bmwpost.ru_AdsPort.zip (18.9 Кб, 154 просмотров)
Tyler вне форума
Эти 2 пользователя(ей) сказали Спасибо Tyler за сообщение:
ulrih (01.05.2011), zass (30.04.2011)
