Старый 17.05.2011, 21:15 #448
Авто: E65 730d
Коллеги подскажите, как правильно прошить е65? Делаю так, как расписано в шапке этой темы. Прошивается все успешно. НО! Вот что написано в мануале по прошивке е65:
LOADING SOFTWARE (E65 AND E66 ONLY)
When programming any E65 or E66 using Progman V27.0 or higher, you will be prompted by the Progman screen that "BMW Navigation CD Version 31" must be loaded prior to programming the vehicle.
Note: Connect an approved battery charger before loading software.
Turn the ignition on to Terminal R or 15.
Enter the Navigation Menu.
Remove the NAVTEQ road map CD/DVD.
Insert the Navigation Operating Software CD V31 (P/N 01 59 0 141 891 index "x") into the navigation computer and use the latest Progman version for NAVI03 (DVD navigation).
Select "Yes" with the controller to install the software.
The software will then load in two steps, taking approximately 10-15 minutes.
Do not touch the iDrive while the software is loading.
When the installation is finished, the CD will be ejected. The message "Installation Successful, Remove Software loading CD and press OK" will appear. At this point, select "OK" with the controller.
The navigation system will then "reinitialize".
When prompted, insert NAVTEQ road map CD/DVD.
Refer to SI B09 05 01 (Coding, Individualization and Programming) for any necessary coding and programming. Note that Progman will automatically reprogram all programmable control units that do not have the latest software.
Drive the vehicle before delivering it to the customer to ensure that the navigation system is functioning and displaying (Interstate Icons) correctly.
Мануал для 31-й прошивки говорит о Progman V27.0 or higher. Что это за прогман такой? Если я делаю так, как написано в шапке темы - все ли я делаю правильно именно для е65.
Serge71 вне форума   Ответить с цитированием
