Старый 18.05.2011, 11:31 #6
М52...я понимаю..что модель..но что означает сие 52?
Это вопрос из той же серии, что означает 39 в е39 и т.п.
Немного не в тему, но, может, интересно:
An "M" means that the engine has been developed by BMW, while an "S" means that it's an M-engine modified for extra performance by BMW Motorsport. Following the letter is a number that identifies the model. BMW usually specifies the engine designation followed by the engine capacity, as the M52B25 is the 2.5-liter version of the M52. The "B" in M52B25 stands for "Benzin", the German word for petrol (UK) or gasoline (USA), whereas a Diesel engine would use the code "D". Finally, sometimes you will see an engine code with a suffix, as the M06 is also known as the M30B25V with the V meaning "Vergasser" or Carburetor.
mihhail (18.05.2011)
