К стати вот нашел как можно сделать
I dont know tool readin fool info from this processors Byteshooter CMD reads but not all if you try clone ecu you cant do this and you will not read memory areae where is isn code (16 bytes) simplest solution replase tricore from orginal ecu to used. in my country it cost 30E-50E, rewrite eeprom memory and your car will start. I did it 3 times and all times everything was ok
напишу ему где он живет может реально просто смогут перелить
