Старый 20.09.2009, 20:01 #11
Мануал по АКПП ZF 5HP19FLA. 59 страниц. .pdf
Содержание:
5HP19FLA Transmission Overview (North American Applications)
Make / Model / Model Year 02
5HP19FLA Technical Information
Torque, Gear Ratio & Weight 03
Transmission Oil Reference Guide 03
5HP19FLA Lubrications 03
5HP19FLA Technical Literature 03
5HP19FLA General Transmission Oil Filling Procedure 04
5HP19FLA General Differential Oil Filling Procedure 06
5HP19FLA General Transfer Case Oil Filling Procedure 07
5HP19FLA Spare Parts
How To Use This Catalog 08
Gearbox Housing Group 09
Oil Sump Group 12
Oil Supply Group 13
Converter Group 15
Planetary Drive Groups 16
Front Axle Differential Group 18
Rear Axle Output Group 21
Front Axle Output Group 23
Internal Differential Lock Group 24
Clutch Pack Groups 25
5HP19FLA Valve Body
Duct Plate Group 31
Valve Housing Groups 35
5HP19FLA Selective Shims, Snap Rings & Kit Content
5HP19FLA Selective Shims & Snap Rings 46
5HP19FLA Kit Content 53
Miscellaneous
Quotation / Order Form 57
Notes 58
Тип файла: pdf www.bmwpost.ru_5HP19FLA.pdf (1.17 Мб, 213 просмотров)
Эти 5 пользователя(ей) сказали Спасибо Tyler за сообщение:
andrey75r (07.09.2011), atanas yanchev (27.08.2014), BAM161 (23.10.2010), Mik78 (12.07.2010), КРУГЛОВ (21.05.2015)
