Старый 08.10.2012, 02:11 #19
всем привет, та-же ошибка. устал бороться. Профиль ключей работает, manual выдает ошибку coapi 1000.
нашел тему на английском форуме, вот выдержка:
"I have found and fixed the problem. The car in question had been converted from an automatic to manual transmission, and the facility that did the conversion also changed the ZCS key. The new key that they programmed was faulty. Part of the key indicated the car was a manual, while another part indicated it was an automatic. This caused NCSEXPER to puke when deciphering it and throw the general error.
After manually correcting the key (changing just 1 bit) and writing it to the pertinent modules, all is well with no errors."
не понял прошлые посты про "FA" и iPOD
Последний раз редактировалось mrzz; 08.10.2012 в 02:27.
mrzz вне форума   Ответить с цитированием
