Сообщение от tt1488 Подскажи пжлст как он навзывается? Пробовал перевести переводчиком все что есть в скм но ничего близкого по смыслу не могу найти...  |
Копай:
E39 Car and Key memory programming using NCS Expert in the Edibas package.
AUSSENTEMP_WARNUNG_GONG : External Low Temp Warning Gong
AUT_SITZVERSTELLUNG : Automatic Seat Adjustment (select when unlocked or when driver door opened) linked to key number
AUTO_ZV_DISABLE :
BC_KL_R : Interior lighting ON when ignition is switched off after driving with headlights on
DWA-QUITTIERUNG : DWA Acknowledgement
EINSCHALTMELDUNG_IMMER : Power-up messgage always
ERKENNUNG_SITZBELEGUNG_1 : Recognition seat allocation (don't switch this off otherwise the airbag system gets up-set)
FH_BEIFAHRERTUER_TIPP_AUF : FH Passenger Door Window Up (one touch window passenger door)
FH_BEIFAHRERTUER_TIPP_ZU : FH Passenger Door Window Down
FH_FAHRERTUER_TIPP_AUF : FH Passenger Door Window Up
FH_FAHRERTUER_TIPP_ZU : FH Passenger Door Window Too
FH_TUEREN_HINTEN_TIPP_AUF : doors in rear Window Up
FH_TUEREN_HINTEN_TIPP_ZU : doors in rear Window Down
fussraumkurven : Floor Space-Circle
HBA_DSC_5_7 :
HECKKLAPPE_ENTSICHERN : Rear BootRelease from remote key
HEIMLEUCHTEN : Home Shine (Follow me home lights)
INNENLICHT_AN_MEHRFACH_ZV : Interior Light On Several Times
KEY_MEMORY_IHK : Key Memory IHK Module (A/C temperature memory from key number)
KEY_MEMORY_RADIO : Key Memory Radio (Radio channel / volume from key number)
KOMFORTOEFFNUNG : Comfort Opening
KOMFORTOEFFNUNG_FB : Comfort Opening
KOMFORTSCHLIESSUNG : Comfort Closing
KOMFORTSCHLIESSUNG_FB : Comfort Closing
LAUTSTAERKE_HINTEN : Volume in the Back
NOTSTROMSIRENE : Emergency Power Siren
QUIT_OPT_ENTSCH : Acknoledge remote un-locking (two flashes)
QUIT_OPT_SCHAERF : Acknoledge remote locking (one flash)
SCHIEBEHEBEDACH_TIPP_AUF : One touch sun-roof open
SCHIEBEHEBEDACH_TIPP_ZU : One touch sun-roof close
SOFT ON/OFF : Soft dim/undim of the interior lights
SPRACHIE : Language selection
TAGFAHRLICHT_ECE : Dayligh Headlights
TEMPERATUR_EINHEIT : Temperature Unit (C/F)
UMLUFT MEMORY : Circulating Air Flap Memory (remembers if re-circ is on after shurdown)
VERBRAUCH D1 : Consumption units
VERRIEGELN_AUT_AB_X_KMH : Automatic locking after X KMH
VERRIEGELN_AUT_MACH_2_MIN : Automatic locking after 2 MIN
VERRIEGELUNGSSCHWELLE : Bolting Device-swells (speed of X above)
WEG_EINHEIT : Dustance unit (distance, mils or km)
ZEIT_EINHEIT : Time unit (12H or 24H)
ZUENDSCHLUESSEL_WARNUNG : Ignition key Warning, a really anoying option which beeps if you leave the key in the ignition
ZV_SELEKTIV : ZV selectively (selective unlocking)
