Старый 15.10.2012, 18:12 #1
По умолчанию замена лампочек освещения салона
Замена лампочек освещения салона BMW F10
Door light, Glove Compartment, Trunk: very simple, just use a flathead to pop it out
Foot light: just pop the left side of the light
It should look like this
Just twist the cover and will be able to replace the lights
Rear dome light: Just have to pop out the clips that surround the doom light. The 2 reading bulbs are harder to get out so I used double sided tape and just tape it to the bulbs and pull them out.
Mirror Light: Just pull out the cover and unplug the wire and remove the metal clip.
Front Dome Light: You have to remove the black cover and you should see 4 holes. You need to use a small flathead and push the clips that's in the L shape holes. (might require a bit of force) And then you just have to pull the surrounding clips around the dome light.
Enjoy your new LED lights
Tyler вне форума
