: BMW F30
замена отражателей (катафотов) переднего бампера
23.10.2012, 00:32
Tyler
Поблагодарили 10,622 раз(а) в 1,958 сообщениях
Замена отражателей (катафотов) переднего бампера BMW F30
1. Locate the three 8mm screws along the front inner fender well.
2. Remove the three screws
3. Once all three are out pull the inner fender away from the bumper
4. Now your going to use a combination of the flat head screwdriver and your hand to pull the reflector away from the bumper.
*Note* do not allow the screwdriver to turn once it is between the bumper and the reflector as this could cause rippling in the bumper itself.
5. Now with the reflector removed you can clean out any remaining molding tape that is on the inner bumper. Also clean the inner bumper thoroughly before adhering the new reflector.
6. Remove the plastic from the reflector so the adhesive is ready then line it up through the inner fender. Once it is in place apply pressure both from the inside and the outside of the bumper to ensure a proper seal.
Now your done! The other side is exactly the same.
Чат по кодированию, программированию, дооснащению BMW в Telegram:
https://t.me/+QiJ7fqL4KrYcxPrx
BMW INPA
BMW ICOM
BMW Scanner
Ключи BMW
BMW CAN filter (cic retrofit adapter)
Отключение BMW EGR / DPF
Ноутбуки для диагностики
Автосканеры, автодиагностика
Сканеры для диагностики BMW
Инструкции, мануалы к БМВ бесплатно
BMW & MINI: TIS, ЕТК, ЕТМ, KSD, WDS, DIS, EBA и другие полезные программы
Меню пользователя Tyler
Найти ещё сообщения от Tyler
