Старый 09.01.2013, 00:14 #5
alex-7-73, не всё тут для е65, но почитай:
QUIT_AKUST_ENTSCH : alarm beep on unlock (two beeps)
QUIT_AKUST_SCHAERF : alarm beep on lock (one beep)
QUIT_OPT_ENTSCH : optical Acknowledge remote un-locking (two flashes)
QUIT_OPT_SCHAERF : optical Acknowledge remote locking (one flash)
ALARM_OPT_ABBLENDLICHT : alarm flashes low beam when tripped
ALARM_OPT_WARNBLINKER : " " emergency flashers when tripped
ALARM_OPT_FERNLICHT : " " high beam when tripped
BEIKLAPPEN_B_KOMFORTSCHL : press the unlock button twice, and the drivers window will open
FH_TUEREN_HINTEN_TIPP_AUF :rear window power down one touch
FH_TUEREN_HINTEN_TIPP_ZU : rear window power up one touch
FH_ZTR_SCHALTER_TIPP_AUF : window switch down one touch
FH_ZTR_SCHALTER_TIPP_ZU : " " up " "
(do these after modifying the switches)
KOMFORTOEFFNEN_FB_O_FH_HI :remote opens rear window (this has to be nicht_aktiv)
KOMFORTSCHLIE_FB_O_FH_HI : remote closes rear window (this has to be nicht_aktiv)
KOMFORTOEFFNEN_FB_O_SHD : holding open button on remote opens windows without sun roof
KOMFORTSCHLIE_FB_OHNE_SHD : holding close button on remote closes windows without sun roof
KOMFORTOEFFNUNG_FB : convertible top opens by holding the open button on remote..Or opens all windows & sun roof on non convertible
KOMFORTSCHLIESSUNG_FB : convertible top closes by holding the close button on remote..Or closes all windows &sun roof on non convertible
MAUT_N_ABBRECH_N_TUER_AUF - windows carry on opening/closing even when you open the door
VERRIEGELN_AUT_AB_X_KMH : automatic central locking after X KMH
VERRIEGELN_AUT_NACH_2_MIN : automatic central locking is re -locked after 2 MIN if you dont open a door
VERRIEGELUNGSSCHWELLE : locking Device-swells (threshold) (speed of X above)
VERRIEGELN_XKM/H_SENDER_1
VERRIEGELN_XKM/H_SENDER_2
VERRIEGELN_XKM/H_SENDER_3
VERRIEGELN_XKM/H_SENDER_4
(these all have to be aktiv for the auto central locking to work on all keys)
PANIK_MODUS - panic mode! press and hold boot button for the siren
CYCL_TI_BLK;1-touch on turn signal blinks. einmal-1 . zweimal-2 . dreimal-3.
One touch indicators, lane change.
BLINKIMPULS_WARNBLK to wert_04 - double impulse hazards
HHS_AUTOMATIK - enable auto rear window fogger
(I haven't found the last three in any module, but I can see it in the full read-out. So if you find it, then tell!!)
FTM/BTM:
SPIEGELABKLAPPEN_GM - folding mirrors with lock/unlock
ABKLAPPWERT_GM (in GM5) - mirror tilt value
ABKLAPPWERT - mirror tilt value
SPIEGELMEMORY - gives you the option to change the mirror tilt value whilst it's in reverse
ALSZ:
HEIMLEUCHTEN : home lights activated by flashing high beam with key off
HEIMLEUCHTEN_ABBRUCH : home light stop
HEIMLEUCHTEN_AL :home lights are low beam
HEIMLEUCHTEN_BL : " " " turn signals
HEIMLEUCHTEN_FL : " " " high beam
HEIMLEUCHTEN_FUNKSCHL :lights on on closing car with remote (only on e39 )
HEIMLEUCHTEN_KL58G : home lights are interior backlighting, cluster, ashtray etc.
HEIMLEUCHTEN_KZL : " " " license plate
HEIMLEUCHTEN_NSL : " " " rear foglight
HEIMLEUCHTEN_NSW : " " " front foglight
HEIMLEUCHTEN_RFS : " " " reverse light
HEIMLEUCHTEN_SL_H :" " " rear parking lights
HEIMLEUCHTEN_SL_V :" " " forward parking lights
FL_UND_NSW_NICHT_GLEICHZ : high beam & fog lights come on together when nicht_aktiv (I haven't got this working yet)
Xenons with high beam:
PWM_WERT2_FL_BIXENON
wert_02
to
wert_01
(I haven't tried this yet)
LED (ALSZ) upgrade:
KALTUEBERWACHUNG_BL_MI : " " " " brake light
WARMUEBERWACHUNG_BL_MI : " " " " brakes
FEHLER_BL_BLINKEN
(if these don't work, then retrofit with GT1 instead).
Seat:
AUT_SPIEGELVERSTELLUNG : automatic mirror adjustment linked to specific key
AUT_SITZVERSTELLUNG :choose between automatic seat adjustment [nach_fb_entriegeln] when remote signals door open or[nach_entr_u_tuer_oeffnen] when door opened
(A bit hit and miss with these)
IHK:
1. DISPLAYANZEIGE_HIGH :temp. display on ihka shows HI if aktive 32*C if not aktive
2. DISPLAYANZEIGE_LOW :temp. display on ihka shows LO if aktive 16*C if not aktive
Others:
REGENSCHLIESSEN - Rain sensor closes sunroof! (I haven't found these yet!)
REGENSCHLIESSENTILT
Car Key memory:
A heres a guide to car/key profile and button in NCS:
The typical sequence for the customization is as follows:
1. Button Select the "individualization".
-> The operating side, the potential for the individualization ZCS FSWs customizable displays the selectable PSWs. The intended state of PSWs is marked with a prefix 'S'.
2. Button Select the "READ".
-> The actual state of the customizable PSWs FSWs is determined and with a leading 'I' marked.
3. Button Select the "TAKE OVER".
-> The currently selected PSW becomes the new target value for the vehicle in the list of gänderten PSWs.
4. Button select "BROADCAST".
-> The controllers of the vehicle in which PSWs have changed are encoded. Amended by promoting PSWs the list of changed PSWs.
alex-7-73 (09.01.2013)
