Старый 17.01.2013, 00:50 #11
Аватар для XCommandeRX
Поблагодарили 10 раз(а) в 4 сообщениях
Авто: E38 740D '00
  • Официальная инструкция по ремонту ZF 6HP19. 102 страницы. Язык - английский. 6HP19 repair manual.
Содержание:
1. General 1.1/1
1.1 Illustration of transmission 1.1/1
1.2 Power flow diagram 1.2/1
1.3 Specifications 1.3/1
1.3.1 Screw specifications 1.3/1
1.3.1.1 Mechatronic type E 1.3/1
1.3.1.2 Mechatronic type M 1.3/1
1.3.1.3 oilsump 1.3/1
1.4 Adjusting procedure 1.4/1
1.4.0 Measuring clutch packs (procedure) 1.4/1
1.4.1 Clearance setting, brake С (snap ring) 1.4/3
1.4.2 Clearance setting, brake D (snap ring) 1.4/5
1.4.3 Clearance setting, clutch В (snap ring) 1.4/7
1.4.4 Clearance setting, clutch A (snap ring) 1.4/9
1.4.5 Clearance setting, clutch E (snap ring) 1.4/11
1.4.6 Clearance - output (disk) 1.4/13
1.4.7 Clearance - input (disk) 1.4/14
(M type only)
1.4.8 Switch setting (detent spring) 1.4/15
1.5 Tightening torques 1.5/1
1.6 Transmission test (test bench) 1.6/1
1.7 Special tools 1.7/1
1.8 Oilflow chart (Position N) 1.8/1
(E - type) 1.8/1
(M - type) 1.8/2
2. Disassembly (разборка)
2.1 Transmission disassembly according to component groups 2.1/1
Dismantling
2.2 Turret (with clutches A and E) 2.2/1
2.3 Oil supply 2.3/1
2.4 Clutch В 2.4/1
2.5 Brakes С and D 2.5/1
2.6 Output shaft with parking lock 2.6/1
2.7 Transmission casing with shift-control and parking lock 2.7/1
3. Assembly (сборка)
3.1 Transmission casing with shift control and parking lock 3.1/1
3.2 Output shaft with parking lock and planetary gear set 3.2/1
3.3 Brakes С and D 3.3/1
3.4 Clutch В 3.4/1
3.5 Turret (drive with clutches A and E) 3.5/1
3.5.1 Clutch E (drive) 3.5/1
3.5.2 Clutch A (input) 3.5/4
3.6 Oil supply 3.6/1
3.7 Mechatronics, oil pan and converter (Complete mechatronics, see spare parts list, technical cover sheet, item Y02) 3.7/1
Тип файла: pdf www.bmwpost.ru-6HP19-repair-manual.pdf (23.70 Мб, 0 просмотров)
XCommandeRX вне форума   Ответить с цитированием
